![]() | Home > INEOS Grenadier > Reserved |
| Hweebe Member Since: 03 Oct 2021 Location: Brisbane Posts: 11
Very good prediction
Confirmation #: 00052622xx |
This reddit thread also contained some good info:
https://www.reddit.com/r/ineosgrenadier/co...;context=3 So is it confirmation numbers or invoice numbers we should go off? |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
I'll check that thread out next
Actually scratch that ~ it appears to require an app to read described as sub optimal in the reviews. OK ~ now in via Google... Can you extract any data from it and cross post here? I'm liking confirmation numbers personally ~ it is the number generated at the point you pay. Invoices are following several hours later, and who knows what order they are being processed in? |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Hmm, that's odd. I've just checked and both the number and email time are definitely correct: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 4th Oct 2021 5:43am. Edited 1 time in total |
Thanks for all of that. As somebody else mentioned, it would be nice if they homologated a 2 inch receiver but I somehow doubt it.
You read my mind 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Reverse engineering the solution - I'm going to suggest it's the difference between GMT and BST. |
| Bev Member Since: 03 Apr 2013 Location: Perthshire Posts: 267
Reservation placed and confirmed on email at 11:03. Number 000xxx74xx 2002 Td5 | 90 County Station Wagon | Oslo Blue
2006 Td5 | 90 County Station Wagon | Tonga Green (Gone ) 2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone) |
Bev - that's not a fit with the data set currently, but error may lie elsewhere...off to check if I've recorded correctly elsewhere.
Scratch that - works perfectly - my cut & paste error |
| Avion8 Member Since: 26 Jan 2015 Location: Perth Posts: 281
Ours is 22xx at 7:49 on 30th Sept West Australian time if that helps! 1955 Series 1 107" Pick up.
1977 RRC Suffix 'D'. 2000 Defender 110 TD5 Xtreme. 2015 Defender Heritage 90. |
| stng110 Member Since: 04 Jun 2021 Location: Melbourne Posts: 102
Do you have a ploy update? |
Update - filled in a few gaps and confirmed upper limit of 8xxx is actually 83xx.
Unsure if we have any known 1xxx confirmation numbers and no 0xxx confirmation numbers so reservations are only known to start at 2xxx currently. Click image to enlarge |
| Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978
Mine is: 00052xxx at 8.00 on 30/9/21
Huttopia - If your full reservation number is in the format #000526XXYY, then I'm looking for the XX numbers.
If 08:00 is BST then I would guess it starts with a 6? |
| All times are GMT |
