Home > Technical > Windshield wipers not working. 1994 defender 90
GRU54
United States 1994 Defender 90 300 Tdi HT Coniston Green
According to my fuse diagram 3 and 4 should power with wipers. Ive checked both and still wipers not working. What should be next step to check before buying another motor? thanks
Post #924135 3rd Oct 2021 4:53am
Dinnu
Check that the wiper spindles are not seized. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #924156 3rd Oct 2021 7:59am
LR90XS2011
unplug the loom from the motor and see if you have +ve and -ve power to the plug, if you do then its the motor or wiper system that needs attention.
dont rush to buy a new motor until you have taken the plug off and checked , also as others have said it may have just stalled due to friction somewhere in the system, and new motor brushs are also available parts are generally interchangeable across the British Leyland range so parts are not a problem DEFENDER 90 TDCI XS,
Post #924160 3rd Oct 2021 8:11am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
The wiper stalk can also be finished, they wear out frequently, if its not any of the other issues. Cheap enough to replace Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #924181 3rd Oct 2021 9:37am
Procta
or the wiper switch itself on the motor. Thumbs Up
Some times a gentle tug on the wiper arm itself, after you switch the stalk down, may get them going again. Just case the switch itself is stuck Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #924301 4th Oct 2021 5:36am
