Home > Technical > another alarm question... SOLVED
Eduardo
Hi there,
Today I check the auxiliary fuse box and take out the 20A fuse from the alarm system to check it for around 1-2 minutes. The fuse were OK and I put it again.
After that when I try to start the car sounds 2 honks and start (similar when you have a door open and you activate the alarm). It was during the nigth in the garage so, I didnt take out the car to see if the inmobilizer start (I dont like to bother my neighbors in the middle of the nigth with a crazy alarm).
Question: Can my alarm system has been desconfigurated and the alarm manual code should be introduced?
I ask that because I dont have the code, so if this is the problem I need to call the dealers tomorrow at 1st hour to get the it
Cheers and thanks. Eduardo
Post #92351 3rd Oct 2011 5:52am
Lorryman100
Try a different fob to eliminate the fob battery first. Also check all doors/bonnet are properly closed as this is the most common source for a mislock tone. The 10AS gets its power from more than one source so pulling one fuse will not disable the 10AS unit.
The defender should start as normal with the fob and key as the settings page within the 10AS needs to be re-flashed with new settings to incur changes otherwise the 10AS would need re setting every time the battery was disconnected. The EKA code is really just a get you home solution to losing/inoperable key fob as it allows the vehicle to be mobilized in an emergency and only lasts one ignition cycle.
After checking the doors are closed and a different fob (battery) and it still does it, try a hard reset by disconnecting the battery for 10 mins before reconnecting to see if this clears the issue. Other than that a capable diagnostic tool will allow you to see what faultcodes are stored in the 10AS and give you live data on the sensor voltages allowing you to see what is causing the issue.
HTH Brian.
EDIT: Just reread your post Eduardo and I completely missed the two honks as you started the defender Embarassed Was the Alarm dash red light flashing fast (Tamper, as you tampered with the power supply with the ignition off and the immobilizer active)?
Post #92369 3rd Oct 2011 9:57am
Eduardo
Thanks LorryMan
I didnt paid attention to the alarm lights when I do the test: I will try again in 1-2 hours to see if the inmobilizer is active or not (still early here in Chile to play with alarms)
Also I forgot to said that both FOBs doesnt work...
The car is open, so the alarm is not active.
Cheers Eduardo
Post #92388 3rd Oct 2011 12:24pm
Eduardo
Lorryman
Just I do the test. The red light are still there when i put the key in the barrel and I move to position 2.
Also the car do 2 honks, cranck and doesnt start. Sad Sad
Cheers Eduardo
Post #92406 3rd Oct 2011 1:42pm
Eduardo
another alarm question: Issue Solved...
After the hard reset 10 min battery disconnected all comming to normal.
Thanks Lorry for your help Eduardo
Post #92408 3rd Oct 2011 2:12pm
Lorryman100
I'm glad I could help. Thumbs Up
The one thing to remember about the Lucas 10AS alarm is that it does most of its work with the ignition switched off, this includes communications between it and diagnostic gear. So when you removed the fuse the unit registered it was being tampered with and would not allow the immobilizer to be reset with just the key. I am curious now as the fobs should have reset the unit though by you arming then disarming the alarm? Are the fobs working? Any other issues with the alarm, starting or running issues that could come down to the passive immobilizer?
Though as I mentioned earlier you can always resort to the hard reset to try and resolve any issues by disconnecting the battery for 10mins to allow any stored capacitance in the ignition circuit to drain allowing the unit to reset. You could probably speed this time up by pressing the brake pedal a couple of times as well, though I haven't tested that theory but will add it to my to do list.
Brian.
Post #92554 4th Oct 2011 10:05am
