![]() | Home > Maintenance & Modifications > Fuel leak (another one) |
| Rivarama Member Since: 28 Aug 2021 Location: London Posts: 155
After a bit of research, I am left unsure as to which part I need to buy. Which of the 2 do I need
LR006866LR or LR019009 The WSM shows the pressure limited valve and the spigot that seems to connect to the fuel line. Any guidance would be appreciated Thanks |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
also try remove and check fit information from work shop manual as you are dealing 2000bar fuel presser
https://www.defender2.net/gallery/albums/u...le0018.PDF LR006866 is valve assy and new copper washer only
LR019009 - is valve assy to fuel pipe work fitting with new copper washer ![]() |
Thanks for clarifying
| All times are GMT |
