Home > Technical > Help getting bonnet prop rod into bushing
apex02
United States
I’m probably missing something obvious here but how do I get the bonnet prop rod on the bracket with the bushing installed? There isn’t enough space between the rod and the hook of the rod to get it on the bracket with the bushing installed. See pic below. Help!!
Post #923429 29th Sep 2021 4:44pm
apex02
United States
Post #923430 29th Sep 2021 4:46pm
Dinnu
Have you tried putting in the bushing last? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #923432 29th Sep 2021 4:48pm
apex02
United States
I’ve tried but once the rod is inside the grommet the grommet expands making it way too big to fit thru the bracket.
Post #923435 29th Sep 2021 5:00pm
ksv
Russia 2007 Defender 110 Puma 2.4 SW Keswick Green
At first put some grease or soap to the bush, then bush into the hole, then bonnet rod into the bush hole. It'll take you for a thirty seconds.
Post #923450 29th Sep 2021 5:43pm
apex02
United States
I have tried this. It’s not the grease thats the issue. It’s the opening of the prop rod hook. It won’t clear over the bracket.
Post #923454 29th Sep 2021 5:50pm
Manipulate it up, so the horizontal long piece starts going though and follow it all the way.
You might need to move it in all sorts of directions to get it through and then back to the position you want it.
Don’t start with the bent piece start with the long section and work it around and through.
You could always warm it as well (only a little) open the gap a little and bring it through. Closing it could be tricky though and I wouldn’t advise this unless you have no other choice.
You should be able to manipulate it to fit properly as it is. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #923455 29th Sep 2021 5:58pm
ksv
You need to fit the rod end, that is in your photo. You need grease to easy fitting the bush into the hole. Try please, it's really easy.
Post #923457 29th Sep 2021 6:01pm
Dinnu
Looks like one of the aftermarket Puma bonnet upgrade (if can be called an upgrade) kits, like what Masai have on their site. I have removed props from Td5s which is very similar, although unlike the Puma version, the Td5 prop cannot pass the long side first as there is an increase in diameter as LandRover used to weld in a tube in the long straight section. I cannot remember having any issues. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #923460 29th Sep 2021 6:04pm
ksv
You need to fit lower end of the bonnet rod into the bush, not the upper end.
Post #923462 29th Sep 2021 6:09pm
ksv
I can make video tomorrow, if you want
Post #923468 29th Sep 2021 6:34pm
apex02
United States
Yes this bonnet prop kit is from Masai. Maybe that is the issue.
Post #923536 29th Sep 2021 9:55pm
apex02
United States
Yeah the lower end will not go in first. Same clearance issue
Post #923537 29th Sep 2021 9:57pm
