Home > Maintenance & Modifications > Footwell repair panels
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
My left hand footwell has rusted through around the air con drain pipe. I’ve managed to hack it out to about a fist sized hole. Unfortunately the rust creeps up past the inner wing brackets but does not seem to have spread very far down. It has however eaten away at the ribs in the steel.
I want to make a repair that looks as close to original as possible but can only find these with the ribs:
https://www.lrbulkheads.co.uk/Land-Rover-9...ing-PAIR-1
Ideally, I only need a repair panel like this:
https://yrmit.co.uk/product/lhs-extended-f...-defender/
Plus the inner skin.
Does anyone do the outer skin with ribs (just the left side) and the inner skin, but with pre cut holes for air con?
Thanks
James 2002 110 td5
Post #923249 28th Sep 2021 7:26pm
Dinnu
Check out this post: https://www.defender2.net/forum/topic77923.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #923251 28th Sep 2021 7:31pm
Jimb1978
Thanks Dinnu👍
I’ve had a quick look at those links and none seem to quite fit the bill, especially needing the air con holes 2002 110 td5
Post #923252 28th Sep 2021 7:40pm
Dinnu
Not an option to cut the AC holes before or after fitting? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #923256 28th Sep 2021 7:51pm
Jimb1978
Yes, I guess I was just hoping for an easy way to get them in the right place. There isn’t much left of mine to take a measurement from Laughing
I was also planning on just cutting out the bare minimum and trying to use only as much of the new panels as needed. Considering the bulkhead is 20 years old it really is on lovely condition apart from this little bit 2002 110 td5
Post #923259 28th Sep 2021 7:58pm
Dinnu
Unfortunately away from home for a while, otherwise would had been happy to measure them up for you. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #923329 29th Sep 2021 7:56am
Jimb1978
I thought I’d give a bit of an update. I’m on the home straight of this job now after three days of pain. I’ve managed to do it without taking the wing off so I guess that’s a positive. I couldn’t wait for the ribbed panels so used yrm.
Thanks for all the help and offers of measuring up. Obligatory pics…
[img][/img]
 2002 110 td5
Post #927079 25th Oct 2021 5:30pm
Jimb1978
Not sure why photos shears get posted in reverse order 2002 110 td5
Post #927080 25th Oct 2021 5:31pm
Dinnu
Great job Thumbs Up
Perhaps consider one of those mud shields to protect the footwell from stone chips, such as made by Gwyn Lewis. Or you can make yours, as the previous owner of my Defender made. They work great in protecting the footwell. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #927197 26th Oct 2021 11:59am
