Home > Technical > Reversing Light and Switch - 05 td5. Now sorted
bodstruck
I have read up where I can and consulted the wiring diagrams LandyAndy kindly sent me a while ago but I can't quite reconcile the wiring colour to what I have.
Mine has no reversing light switch. I am assuming that all the wiring will be there and it has either been removed and blanked or was not fitted from the start.
I am assuming that the plug with the black and white wire is the connector for the reversing light switch. I have unearthed a black and white wire pair tucked away in the NSR which I think are the wires for the reversing light. Not sure about the single wire - yellow with white trace.
There is 12v across the terminals in the plug. Perhaps as simple as fit a switch, connect the plug and then fit a light at the other end. Or am I missing something?
Post #923010 27th Sep 2021 2:09pm
rallysteve
reverse light switch should have green/yellow and green/brown cables.
The single cable may well be for the handbrake warning light switch but is white with yellow trace. Usually terminated with a single female bullet terminal somewhere above the transfer box.
Post #923015 27th Sep 2021 2:32pm
geobloke
If the single wire is the handbrake switch wiring it will pass through the bulkhead to the switch attached to the handbrake lever.
The reverse light switch connector is high up on the R380 gearbox. To get to it crawl underneath and look up just in front of the seat base on the passenger side. You should see the switch on the passenger side of the gearbox.
You can see the switch, wiring and connector hanging off the R380s extension housing in the below photos
Post #923022 27th Sep 2021 3:39pm
geobloke
Actually the best way of getting a look at the switch is to pop the transmission tunnel off and it is just there (silver/gold) cylinder just behind the wiring loom. The reverse wiring connector can be seen in this photo too.
Post #923023 27th Sep 2021 3:42pm
bodstruck
I might be looking in the wrong place then. I assumed that this was where the reverse switch was supposed to be. But this is accessed from under the middle seat, not within the transmission tunnel.
Post #923024 27th Sep 2021 3:53pm
That's the side of the transfer box. Darren
Post #923028 27th Sep 2021 4:10pm
rallysteve
That blanking plug is for the transfer box temperature warning light switch (never seen it fitted on a defender). My V8 discovery had one
Post #923029 27th Sep 2021 4:14pm
bodstruck
Thanks all, nearly there now.
Took the tunnel off to gain access. Found the switch. The connector had come apart. There is voltage across the plug but the switch is not making the circuit
I shorted across the pins with wire and the test lamp I have at the rear lit up.
New switch it is then. Thanks for the pointers Thumbs Up
Post #923043 27th Sep 2021 4:58pm
Steve
Only V8 Disco LT230s were fitted with the sensor (it is a quick way of telling if the box came off a VCool.
Post #923061 27th Sep 2021 5:58pm
