Home > Technical > TD5 Alternator Oil Return Pipe - SQC500010
geobloke
Howdy folks. Weird one tonight. The oil return pipe on Miffy is wearing a fair amount and I suspect it need replacing.
The part number is SQC500010 (supersedes ERR6996) - Number 10 in the below image
It's no longer available anywhere... Shocked Anywhere...!
It is only a pipe, but does anyone happen to know its internal diameter so I can buy the right size pipe, please?????
Post #922897 26th Sep 2021 8:12pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Not sure, but I have just used a bit of fuel line, I think it was 8mm internall diameter. My pipe was OK, but the original pipe clamps were no more tight enough, so it was leaking oil. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #922941 27th Sep 2021 7:07am
rallysteve
10mm ID (3/8") and 17mm OD.
Just replaced mine using some oil delivery hose. Original hose clips still fitted fine, if a bit on the tight size.
I do have plenty of offcut but I dont have any at home to send I am afraid.
Post #922952 27th Sep 2021 8:33am
geobloke
Brilliant Gents. I knew someone would have done this Bow down Couldn't have been the only one with a weary oil pipe.
No problem with the not being able to send you done more than enough Steve. Thumbs Up
Time to find some pipe Smile
Post #922957 27th Sep 2021 8:54am
rallysteve
No probs Thumbs Up
In case it helps, i bought ebay item: eBay Item No. 111569393001
Cheers,
Post #922958 27th Sep 2021 8:57am
geobloke
Thanks Steve. Thumbs Up
Parts are on their way, 50cm of hose and two Mikalor springs clips for £4.50.
Be GONE weary leak.... Whistle
Post #922976 27th Sep 2021 10:10am
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
amazing thread
Thanks for having picked this up and shared the ebay link
also out of curiosity, that OEM clamp used. what tool is used to open these up? they are a major pain to get off ...
thought the Mikalor clamps are one kind but these were different all together Td5 110 Station
Post #974567 13th Dec 2022 4:04pm
geobloke
Quote:
amazing thread Report post
Thanks... Thumbs Up
There is more in the Miffy thread, about halfway down the page - https://www.defender2.net/forum/topic53859...;start=285
The tool you need to undo those spring clips is either - https://www.amazon.co.uk/ACHANFLY-Ring-Typ...KQ2U81CV7O
or
https://www.amazon.co.uk/FAVENGO-Pliers-Fl...amp;sr=8-6
It is the same tool used for the cam cover breather pipe clips as well so well worth having in your toolbox.
Post #974568 13th Dec 2022 4:11pm
