Home > Puma (Tdci) > 2010 2.4 Puma Gearbox fill plug - part number?
24heuer
Scotland 2010 Defender 110 Puma 2.4 CSW Keswick Green
Hi,
Hoping someone can help me.
Was going to change the gearbox oil and I noticed my gearbox fill plug hex centre has been rounded off - I've managed to slacken it off and I now plan to swap it out when I change the oil.
I thought the part No was LR005008 so ordered one up but looks to be a smaller diameter than the current fill plug although it does have the same 8mm hex centre.
Maybe the fill and drain plugs aren't the same and I ordered up a drain plug(?)
(For obvious reasons I can't remove the drain plug to check Smile )
Anyone know if the fill/drain plugs are the same as each other and what the respective part numbers are.
Thanks for looking Bow down Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #921989 19th Sep 2021 1:03pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Could you swap it with the other similar plug that’s on the same side of the gearbox? It’s the one that is quite easy to mistake for the fill plug, but it isn’t.
Post #921991 19th Sep 2021 1:44pm
24heuer
hi piechipsandpeas - thanks for the reply - where would that be in relation to the fill plug? - I can feel another plug higher and more forward of the fill plug but that has a larger than 8mm centre in it.
Not sure if I'm following you correctly but that still leaves me with a plug with rounded off hex centre? Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #921993 19th Sep 2021 2:15pm
Dinnu
I have seen on a Transit manual that the fill plug is further aft than that stated on the Defender manual. IIRC the Transit manual was saying fill to spill.
Form your description, it looks that your damaged plug is the one described in the Transit manual.
IIRC, when I changed the oil, both fill and drain were the same. Still does not solve your problem. But could be that the supplier sent you wrong item? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921996 19th Sep 2021 3:02pm
24heuer
ok thanks, so can anyone confirm the part number is correct? Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #922007 19th Sep 2021 5:56pm
piechipsandpeas
Hi 24heuer
Yes I was thinking of the one further forward (mine both use an 8mm allen head) but I've just removed them to check and they are slightly different thread sizes. Sorry.
Post #922076 20th Sep 2021 12:06pm
24heuer
hi piechipsandpeas - thanks so much for checking.
are you saying that your fill plug and drain plug also have different threads from each other?
I'm getting a bit paranoid that I removed the 'wrong' fill plug. Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #922079 20th Sep 2021 12:10pm
The only contendoers I can see on LRCAT are:
LR005009 - COVER - OPENING PLUG - TACHOGRAPH HOLE
LR005008 - PLUG OIL FILLER PLUG PLUG - OIL DRAIN
It may be that you have removed the former, it is different to the latter which is (apparently) common to both drain and filler.
There are also the following plugs etc on the casing, but I doubt that it is one of these you've take out:
LR005002 - PLUG - BLANKING 20MM - There are two of these and they don't have hex socket heads, they look more like core plugs
LR004966 - PIVOT [ - (V)7A999999 ] - These are the selector fork pivots, if you've taken one of these out you are in the soup.
LR008204 - PIVOT [ (V)8A000001 - ]
LR016958 - RETAINER - INTERLOCK SPRING - Not quite sure about this, but if you've taken it out a spring will have followed.
Note that all the above is based on LRCAT, unfortunately both my spare MT82s are in my unit and not immediately accessible to look at.
Post #922084 20th Sep 2021 12:26pm
piechipsandpeas
24heuer
Not sure if the drain and filler are different threads as I didn't remove the drain plug (the one underneath the gearbox). Photo shows the 2 I removed on the side of the box. The one towards the front of the vehicle (the black coloured one) is not the fill plug but is often mistaken for it.
Post #922089 20th Sep 2021 12:46pm
24heuer
ok, thanks all - I think perhaps I may have removed the wrong plug Rolling with laughter
I'll have another look at the weekend.
Thanks a lot for taking the time to check and reply Bow down Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #922091 20th Sep 2021 1:00pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Did anyone find the correct part numbers for both these bolts in the end?
Post #1032117 19th Apr 2024 8:55am
Ianh
The fill and drain plugs are part number LR005008. I’m not sure about the “not the fill plug”.
See part 7 in diagram. https://www.lrworkshop.com/diagrams/land-r...case_45025
Note . I replaced my fill and drain plugs with magnetic ones that have a Hex head. Obviously the fill plug is above the oil level, so the magnet makes no difference. However I used the magnetic drain plug their as the hex head helps when fitting and torquing, plus eases removal and identification for next time.
https://foundry4x4.co.uk/index.php?route=p...duct_id=64
Post #1032122 19th Apr 2024 9:18am
