Home > Tdi > Light switch info
spudfan
Ireland
Light switch info
Which of these fits the 300 tdi
https://www.lrdirect.com/prc3430-supplied-...nded-lucas
https://www.lrdirect.com/amr6104-supplied-...nded-lucas 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #921868 17th Sep 2021 11:55pm
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
You want the first one, i've just changed mine on my Tdi and that's what was on mine.
Post #921880 18th Sep 2021 8:06am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Does it depend on your connectors? That one recommended has bullet connectors but check your old one as it may have pin connectors as ithe wiring may have been updated at some time. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #921885 18th Sep 2021 9:05am
spudfan
Ireland
The vehicle is not mine and is not here. It is a "J" registered 300 tdi, one of the very last. I know they changed connecting ends but was not sure when. I have a 200 tdi but I was not sure if the 300 tdi usedthe same connecting ends. Thanks. 1982 88" 2.25 diesel
Post #921899 18th Sep 2021 10:44am
Whirly90
If it’s a ‘J’ reg then it would have been a 200 tdi from the factory so it’s obviously been modified, it’s probably best to check the old switch before you order in case there have been any other modifications.
Post #921901 18th Sep 2021 10:52am
dorsetsmith
97 - 99 connector manual for TDI 300 show newer type blade connector for switch lighting C041 but as always best check
Post #921904 18th Sep 2021 11:15am
spudfan
Ireland
Thank you. It is my daughter's 90 and she lives away. She will be here next week so Iwas going to get one and change it for her. Seems like the simplest thing to do is to order one of each! 1982 88" 2.25 diesel
Post #921906 18th Sep 2021 11:36am
spudfan
Ireland
My duughter's chassis number begins VB67WA.
So does this come under
VIN 6A999999 or
VIN 7A000001 1982 88" 2.25 diesel
Post #921907 18th Sep 2021 11:59am
dorsetsmith
6A = 2006
7A = 2007
Post #921910 18th Sep 2021 12:34pm
dorsetsmith
VIN 6A999999 or
VIN 7A000001
No
VB67(WA) V=90" L/R B = 2 Door station wagon 6= engine type ? 7 = gear box type 5 speed RHD WA= 1998 in Solihull build
Post #921912 18th Sep 2021 1:11pm
spudfan
Ireland
Thanks for the info. I have ordered one of each just to be sure!! 1982 88" 2.25 diesel
Post #921913 18th Sep 2021 1:15pm
