![]() | Home > Tdi > Clutch problem |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2395 ![]() ![]() ![]() |
Hopefully it's just a low fluid level and not the pushrod starting to go through the clutch fork
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
SimpleSimon Member Since: 05 Sep 2021 Location: Worcestershire Posts: 43 ![]() ![]() ![]() |
Hopefully...
Not a lot of fluid went in, but I'm guessing there isn't all that much in the system anyway? 1998 300tdi 90 Hard Top. Daily driver, dog bus, shooting wagon and ongoing project! |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 870 ![]() ![]() ![]() |
Master cylinder leaking usually results in a damp patch on the floor mats as the fluid runs down the pedal arm and drips onto the floor.
Leaky slave cylinder will not show at the outside of the cylinder but will leak into the bellhousing and drain out via the drain hole at the bottom of the bell housing. It could be really slow so might only look damp rather than a drip here. Check the wading plug isn't fitted in the drain hole, if it is your bell housing will just be filling up with any fluid that leaks from the slave cylinder or the engine/gearbox oils! |
Thank you, there is indeed fluid coming from the drain hole in the bell housing. Evidently I didn't understand the concept of the slave cylinder leaking, I was looking for fluid on the outside
![]() She's going in to the garage next week anyway for a service and check up, so I've asked them to replace the master (just in case) and slave, and the hose. In the meantime I'll just keep topping it up. I found an opened bottle of fluid behind the drivers seat when I was giving it a good tidy/clean (after the problem arose) so I suspect the last owner was aware of the problem... 1998 300tdi 90 Hard Top. Daily driver, dog bus, shooting wagon and ongoing project! |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Have a think about the LoF replacement master cylinder (from LoF clutches) whilst your at it, they get rave reviews on here. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
