![]() | Home > Puma (Tdci) > OMG MAF cleaned and WOW |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2672 ![]() ![]() ![]() |
Just a BIG THANK YOU for those adding value to this thread, especially the OP.
My Defender is 10 years old, and 52k miles (owned by me from new, with no maintenance given previously to the VCV or MAF). Had a few sporadic issues with my Defender 2.4 TDCI recently. including intermittent power loss, not being able to rev out, and even stalling on idle. I changed the VCV a couple of weeks ago, it did make some improvement but still having some issues. Cleaned the MAF today with Comma Contact Cleaner (from Halfrauds) and Yay! Back to full performance. Thanks guys...wealth of knowledge on here ![]() |
What/where the h*ll is that Hank? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2472 ![]() ![]() |
LRA, I think that 3rd green coloured sensor you show is an “Air Charge Sensor” part number LR032216 That’s what LR call it but in reality I think it’s an Air Charge Temperature Sensor. Listed as part 8 on this diagram https://www.lrworkshop.com/diagrams/land-r...es_2.2tdci Noting I can’t see the equivalent sensor on the 2.4. My understanding of the roles these sensors perform. So function wise the MAF is measuring the volume of air from the filter box on its way to the turbo, the turbo is compressing the air but in doing so also heats it, so the compressed air is sent to the intercooler to be cooled and increase its density, the Air Charge Sensor is measuring the temperature of the air exiting the intercooler and heading to the inlet manifold and the MAP sensor is measuring the pressure of the air in the inlet manifold. These three sensors are providing inputs that are used with other inputs to determine and provide the optimum fuel air mixture at any specific time. So having them all nice and clean and sending correct data to the ECU is key . Noting that 3rd (green coloured) Air Charge Sensor that LRA highlighted seems to get missed out in other threads but I expect it plays a key role as well. |
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Some days ago, I just read that recommended cleaners were 99% white gas or paraffine ![]() They list the substances on their product sheets... |
Rich01483 Member Since: 26 Jul 2021 Location: Uk Posts: 15 ![]() |
Thanks everyone for this, lots more to add to the to do list!
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 159 ![]() ![]() |
Found this thread a couple of weeks ago and have now had the chance to use brake cleaner to clean all 3 sensors highlighted in @LandRoverAnorak 's post. 32K mile 2.2 engine and only the MAP sensor appeared at all grubby and that only looked vaguely sooty. So no particular expectation of noticeable improvement but it has mostly eliminated a bit of a tendency to lurch when driven slowly and stutter on part throttle at a steady 60mph.
The aerosol brake cleaner smells like tetrachloromethane (or carbon tetrachloride if you are older). Used to be recommended in the 1960s for removing beach tar from clothing. Cheers, Guy. |
Brake cleaner should not be used on the sensors, you need to use specialist MAF sensor cleaner such as Liqui moly air flow sensor cleaner, else you can likely do more damage than good. It not expensive and you only need a little on each sensor.
