Home > General & Technical (L663) > Testing the maximum side slope angle.
camelman
Post #921277 13th Sep 2021 12:49pm
Rashers
Ran out of talent šŸ˜‚
I wouldn’t think the insurer would pay out if this video was found by the underwriter.
Post #921278 13th Sep 2021 12:58pm
Simon Audi
Looks like its China - a little filler and few rattle can and the rest will buff out in the local body shop...
Post #921280 13th Sep 2021 1:44pm
lohr500
Must have overloaded the noodles in the side storage locker.
Post #921287 13th Sep 2021 3:40pm
Simon Audi
Does the car alarm if you get near the tip point ?
STOP YOU IDIOT or similar - or just a BOING.... ? Maybe nothing as its too slow to react?
Post #921288 13th Sep 2021 3:47pm
markb110
On a positive note………damn, that underside is clean….. Very Happy
Post #921293 13th Sep 2021 4:32pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Car feeling sleepy…….. Car lay down for little sleep……..😓😓😓😓😓
Post #921298 13th Sep 2021 5:06pm
Pretty sure that will be a write-off, all the o/s panels dinged and at the very least the side curtain airbags deployed. If not a write-off it will be a very expensive repair, what a Censored !
At least the hazard lights came on automatically to keep everyone safe (another utterly pointless feature of modern cars - it would be more sensible if the battery auto-disconnected in an accident).
I presume that it isn't possible to switch off all these systems (airbags etc) when you don't want them on? Ironic that the car is clever enough to turn the hazards on, but not clever enough just to stop when it is about to fall over.
Post #921300 13th Sep 2021 5:13pm
Loafer
The point of the hazards is to alert people coming up on a crash, so they don’t crash into you and create a pileup.
Equally, if you crash off the road, hazards help draw attention to the wreck…you will have seen that recent horrific case where people died after being in the wreck of their car for several days. Carpathian Grey 110 D300 HSE
Post #921301 13th Sep 2021 5:22pm
Philip
Pretty sure most modern cars have some sort of battery disconnect system in the event of a crash (pyrofuse or otherwise).
Do you really want the airbags not to work when you turn your car over?
Post #921303 13th Sep 2021 5:27pm
lohr500
My money says it will be a write-off as well. Suspect unless it was smart enough to shut down the engine, there will be all sorts of issues with oil starvation and excess oil getting thrashed about under the piston skirts.
Post #921307 13th Sep 2021 5:39pm
Rashers
Smart? JLR probably knew it had rolled before the driver Rolling with laughter
Post #921311 13th Sep 2021 5:51pm
Under some circumstances, absolutely, you bet I do.
I've not come across anything as sophisticated as a pyrofuse on a light vehicle yet, and a megafuse is likely to be very little use. You can weld without blowing a megafuse, so setting a vehicle on fire without blowing the fuse is easy.
Post #921316 13th Sep 2021 6:30pm
I suspect that (like rear fog lights) this is an idea which someone thinks is good and which has absolutely no real world supporting evidence. If you need the hazards on to avoid an inverted car in the road, you shouldn't be driving. Then again, as so many of the people on the roads today clearly shouldn't be driving, perhaps it is a good idea.
Post #921317 13th Sep 2021 6:35pm
Philip
If you’re wearing a seatbelt, I can’t think of a situation.
As above, lots of cars have had battery safety disconnects for years, pyrofuse or otherwise. I’ve just spent ~Ā£400 swapping the explosive ā€œbattery safety terminalā€ and harness on an old BMW.
Post #921322 13th Sep 2021 6:52pm
