Home > Maintenance & Modifications > Roof Console + Sub + Rear Speakers - NEW PICS
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Hi
Had a lot of stuff to fit on my DC since March, but as I had a bike accident could only do it these days ...
This is what I had, have ...
The CB antena
The rear speakers and subwoofer
The roof console
The cables ... as I don't have carpets ... and did not have patience to remove the whole roof lining ...
Now I have all the cables tied around the gearbox lever, waiting for some extra money to take it to an electrician to conect the subwoofer, CB and speakers ... The electric feed to the CB is hanging on my seat ... Razz ...also waiting...
The extra driving lights are waiting for an A-Bar ... Mr. Green But I allready have the wiring and the original LR switch to fit on the dash !
I'll post more pics when the Job is complete! Thumbs Up Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #86516 29th Aug 2011 2:06pm
wslr
How does the roof console fit?
Post #86521 29th Aug 2011 2:25pm
TC
Looks good Thumbs Up
Post #86524 29th Aug 2011 2:56pm
lrmaniac
Not sure if I understand your question ... But it fits fine. Fitting it was easy. It brings a support to the back (although I drilled two holes on the wrong side because the instructions are not very clear ... but the console fits over those holes so you can't see them! Razz). In the front it uses the rear view mirror support (btw one of the nuts of the support that should be welded went inside the roof lining - don't have the patience to remove the entire roof to find the nut - don't know how I'll secure the missing screw!) The sun visors were cut by 10 cm and took them to an upholsterer. Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #86526 29th Aug 2011 3:04pm
wslr
Thanks, that answers my Q. Looks pretty OEM really.
Post #86531 29th Aug 2011 4:41pm
lrmaniac
Everything done now
the subwoofer remote
rear speakers
the CB ... For your knowledge the CB I bought (Midland 220) is too long ... the back touches the support brackets of the console, and the radio stands out a little ... Sad I have a friend that has a President (don't know the model) that fits perfectly
 Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #89050 14th Sep 2011 10:03am
pom
looking good Thumbs Up
Pom
Post #89055 14th Sep 2011 10:24am
You can not beat a good sound system in a Land Rover Cool
Post #89058 14th Sep 2011 11:04am
Thumbs Up Whistle
Post #89059 14th Sep 2011 11:13am
lrmaniac
...the diference in the sound with the sub conected is unbelievable!!!! Mr. Green This Clarion sub is very good ! Thumbs Up Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #89060 14th Sep 2011 11:23am
dgardel
Italy
Me too I'm waiting the roof console.....
May be tomorrow will arrive and saturday I'll install it Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #89070 14th Sep 2011 1:12pm
lrmaniac
Then show us some pics, to see if it fits the same ... If you're going to fit a CB, measure the lenght inside before you buy it! Embarassed
BTW, dgardel or anyone else, when I was fitting the front bracket, one of the nuts belonging to the screws that secure the mirror bracket (wich is used to fix the one of the console bracket) went inside the roof lining, so now I only have 2 screws securing the front bracket. any idea on what can I use to replace the missing screw ? Tried some self tapping metal screws but the ones that fit are not large enough to be tighten ... I'm affraid that with only two screws, wont be enough to secure the console over time ... Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #89074 14th Sep 2011 1:33pm
dgardel
Italy
I just installed 3 of this roof on friend defenders and I do not remember this problem....
I'll let you know about mine....
no CB on the vane, I'll install a blank DIN cover with the Webasto timer and a couple of Carling switches (heated mirrors and......) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #89083 14th Sep 2011 2:35pm
dgardel
Italy
I lengthen the holes of the plate fixed on the base of the internal rear mirror to "move" the console upward.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #92121 30th Sep 2011 4:09pm
