Home > Technical > How do I diagnosis where the diff has been welded
dcraig123
United Kingdom 1986 Defender 90 300 Tdi PU Corris Grey
Hey everyone, ok I bought a 1986 90 300 TDi. I made the stupid mistake of buying it without seeing it in person and just video chatting with the seller. When it arrived and I drove it I realised you can not take it out of diff lock. It just changes from Hi - Low. I contacted the seller and they seemed to be unaware of this issue, I managed to get them to contact the owner before them and he said he has welded it into the lock position. Unfortunately I can no longer get them on the phone. I know this is a total school boy error but I need to get it fixed.
What step should I take to find where he welded it?
Thank you,
Daniel
Post #919129 29th Aug 2021 8:34pm
Dinnu
I understand that you are referring to the center diff. That would be strange, because driving on tarmac with the center diff engaged will stress it out and feel awkward especially if turning left or right.
But how about you make a simple test. With wheels chocked, main gearbox in neutral, handbreak off lift one wheel at a time... are you able to rotate the wheel which is off the ground? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #919139 29th Aug 2021 10:37pm
Tim2809
Firstly with main gearbox in neutral jack up a front wheel with handbrake on and see if you can rotate the wheel to prove its actually in diff lock. If it wont rotate then it suggests its locked.
Next thing to do same on the other front and then chock front wheels and let handbrake off and repeat on the rear 1 off the ground at a time. If any of them rotate then it suggests either a diff or half shaft issue on the wheel that turns.
He may have locked the diff because hes blown part of the drive train
Post #919140 29th Aug 2021 10:46pm
Co1
What Tim said. The only reason for welding it locked would be because he has snapped a drive shaft somewhere or another part of the transmission. It’s quite an extreme solution as a half shaft isn’t all that expensive! Interested to know what you find.
Post #919156 30th Aug 2021 6:03am
dcraig123
Ok so the guy had welded the rear diff. The rest of the drivetrain seems fine. He had put 4" lift on the vehicle so maybe that was why he welded it??
Post #921177 12th Sep 2021 4:51pm
I think it more likely that he welded it because he was stupid. The fact that he put a 4" lift on tends to support this theory! Rolling with laughter
Incidentally the rear diff being welded would have no effect whatsoever on the high/low change nor the centre diff lock, and is inconsistent with your opening post. How have you established that he welded the rear diff?
Post #921197 12th Sep 2021 6:13pm
Gasket
As above - there seems to be a bit of confusion here. Welding the rear diff wouldn’t affect the diff lock disengagement.
My theory would be that the diff lock lever is gummed up and jammed over to the right. Not beyond the realms of possibility as the mechanism can certainly get bunged up stopping you changing from high to low.
Think the “welded rear diff” is a red herring that is unrelated: how knowledgable is the seller? (by the sounds of things a trader?). If they’re clueless, they could think this is a perfectly plausible explanation.
The only “acceptable” reason for welding a rear diff (actually just the casing) that I know of in LR circles is when pegging a diff to add a slip bush to prevent the crownwheel from wobbling about.
Outside of LR circles, some hooligans weld up the rear diff (literally, welded gears) to lock the rear shafts so that they can drift it into an early grave.
Could the previous owner have done this to make it have a permanently locked rear diff? Possibly, but you wouldn’t use it on the roads, it’d be something a farmer’s kid might do to a farmyard hack if it’s only being used in the fields or permanently off road.
It does sound like a silly previous owner and an uninformed seller.
If you’ve bought it from a trader the. I’d argue that the vehicle isn’t fit for the road if you can’t disengage difflock nor would it be fit for the road if the rear diff has indeed been welded and in either case they should pay to put it right. If a private seller then you’re on your own but either fix should be relatively easy.
If the linkage: remove, clean, grease and refit.
If the rear diff: slide out the halfshafts, remove diff and fit a second hand one off eBay.
Both jobs can be completed on the driveway in a day or by any specialist in a few hours.
Post #921200 12th Sep 2021 7:11pm
Gasket
Hang on… daftquestion - but how do you know that difflock won’t disengage? Is it that the lever is stuck to the left or is just that the light still illuminated after you think you’ve disengaged it with the lever?
If it’s just the light then after moving the lever back to disengage the diff lock it can take a short drive (100 yards or so) before the light comes back off - have you tried to drive it at all, it hasn’t just been sitting still has it?
Post #921202 12th Sep 2021 7:13pm
Dinnu
The good news is that the diff pin will not fail. Rolling with laughter 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921236 13th Sep 2021 6:11am
