Home > Technical > LT230 whine on over run after oil change
Co1
Morning all. I changed my transfer box oil a few weeks back now and ever since I’ve been getting a whine in over run when above 40mph ish. I used 75W90, not sure what was in before but there was no noticeable noise. The noise isn’t getting worse. Any thoughts? Should I swap for a mineral oil, would that make it quieter being a bit thicker?
Post #920961 11th Sep 2021 7:32am
Grenadier
I think there’s a debate on here as to whether you fill with specific amount (2.6l I seem to remember - but do check) or up to filling hole, and what the results are after. Which did you do? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #920966 11th Sep 2021 7:56am
Co1
Filled her up by volume, but that did end up just a shade below the hole.
Post #920972 11th Sep 2021 8:27am
Grenadier
Sure someone will advise on oil type etc. Interesting as I’m doing mine today. Could it be something else in/around the box? Monsieur Le Grenadier
Post #920978 11th Sep 2021 8:59am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Are you sure it’s your lt230? Whine on overrun tends to be diffs as most likely culprit. You could pull your propshafts one at a time and test drive to eliminate either axle from the equation. When taking the rear one off, remember to make sure your handbrake cover screw is tight.
Post #920998 11th Sep 2021 10:15am
Dinnu
75W90 is what the manual states.
I had a whine for a very long time, but was constant. Turned out to be the handbrake shoes rubbing on their sides against the drum. Old handbrake mechanism though. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921001 11th Sep 2021 10:25am
Co1
Swapped the oil out today after about 1000 miles. I found a single piece of metal in there, along with a small amount of filings on the magnet. The piece is as per the pic. Clear machining marks on one side and not on the other. I sieved
the rest of the oil and found nothing. If this were a gearbox at work I wouldn’t be over worried about the single piece of metal, but the oil looks a bit dark to me. It doesn’t smell bad. Any thoughts?
Post #921628 15th Sep 2021 7:04pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
For 1000 miles it looks dark to me Col. Rgds.
Chris
Post #921635 15th Sep 2021 7:38pm
Co1
I thought it was a bit. Test drive in the morning so I’ll know whether it is still whining. The synthetic oil that came out was body temp to the touch as it had only been sat in the drive an hour or so, the mineral oil that replaced it was noticeably thicker at around 25c. Time will tell.
Post #921640 15th Sep 2021 8:08pm
Dinnu
Perhaps the synthetic oil had more detergent and has cleaned some old muck that was clinging inside. Fingers crossed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921651 15th Sep 2021 9:09pm
Co1
Cheers Dinnu. Here’s hoping!
Post #921657 15th Sep 2021 9:30pm
Co1
20 mile test run this morning and noticeably quieter. Interesting!
Post #921677 16th Sep 2021 8:04am
dailysleaze
Was it EP75w90 you used initially, or manual transmission 75w90?
Post #921688 16th Sep 2021 9:59am
hank
Interested to hear what oils you put in before and after! > 110 XS Double Cab
Post #921693 16th Sep 2021 11:50am
Co1
There’s a question. I’ll have to check, but what is the difference and what would the effect be?
Col
Post #921700 16th Sep 2021 12:28pm
