Home > In Car Electronics > Another morning drive another issue
karlp606
United Kingdom 1997 Defender 90 300 Tdi CSW Firenze Red
Laughing Laughing Laughing
So upon my morning commute I stuck my side lights on (1 push forward of the stalk) then put my main dipped beam headlights on (2nd push forward of light stalk) - but nothing just still sidelights, tried my fog lights - bulbs are coming on full beam so obviously cant be the bulbs or fuses for the head lights :/
Ive done some search and found a pink relay can burn out or loosen? I think its behind the binnacle and not the usual gear box fuse box location.
I had an alarm installed last week where he had to take the binnacle off so possibly caused a loose connection somewhere on the relay that runs the dipped headlights?
Post #920812 10th Sep 2021 9:10am
donmacn
That pink relay is the 'dim dip' relay - a useless and obsolete thing LR fitted to cars of a certain vintage. Something to do with lighting regs at the time.
I forget the age of your car, but my '94 had it. If you Google or search here there will be threads showing how to disable it. I' ve done it, but so long ago I can't remember the details. So I can't remember if the relay remained in place, but I think you remove it and just put a small 'jumper' wire across two of the terminals in the base. There's also a resistor under the top of the drivers wing that needs disconnected.
Have a look at 'dim dip' though - I think that's where your issue is. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #920820 10th Sep 2021 10:37am
karlp606
Thanks Donald - mines a 97 90' County.
I've done a few searches on the dim dip and seems to suggest the relay issue, as everything else looks good fuses, bulbs, contact switch on the stalk etc :/
Hate taking the binnacle out lol Always ends up in a lot of swearing!
Post #920824 10th Sep 2021 10:58am
Dinnu
The grandfather of DRLs
https://www.lrworkshop.com/parts/YWZ10003L
There is also a link how to bypass.
On my MY88 I have the older pulse width modulator. I ran with it disconnected for many many years. But since I am restoring it, I thought I would fix it and installed better current handling transistors inside. I think it looks cool. But the pink relay use different principle, so I am not helping you. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #920842 10th Sep 2021 12:22pm
karlp606
So turns out to be the the main headlight stalk with the contact as its melted, it looks as thought the smaller stalk just sends the feed to the bigger stalk (fog/horn stalk) which then turns the dipped beam on if the contact is working mine has slight play in it so the dipped beams are working. So looks like a new stalk for me.
Post #920859 10th Sep 2021 2:36pm
karlp606
PS My indicators dont cancel automatically after turning, Is this normal lol?
Post #920866 10th Sep 2021 3:06pm
Dinnu
No, that is not normal. On the column there is a bluish thing that locks to the steering (2 prongs on the steering wheel). Ensure that those 2 prongs connect well onto the respective slots in that bluish thing. But probably the steering will become tight if not. Then when that bluish thing rotates with the steering wheel, it pushes a lever that cancels the indicator. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #920868 10th Sep 2021 3:21pm
karlp606
Great thanks
Just seen this https://www.brit-car.co.uk/product.php/884...ng_def__ma
Think Im missing this :/
Post #920870 10th Sep 2021 3:24pm
karlp606
Looks like I’m missing the plastic 2 prong cancelling ring that sits in the blue indicator ring Sad.
I’ve seen some plastic ones on eBay but is there a official LR metal ring? Would rather something more sturdy.
Post #920999 11th Sep 2021 10:23am
Dinnu
To my knowledge, the 2 prongs are part of the steering wheels on the original Landrover steering wheels (metal prongs covered in plastic), so doubt if there is anything that could be genuine, unless you get a complete steering wheel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921002 11th Sep 2021 10:29am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
The genuine LR one is plastic. Rgds.
Chris
Post #921008 11th Sep 2021 11:35am
donmacn
One of the problems with the LR headligt wiring is that the full current for the lamps goes through the switch on the column. Eventually they will melt. To be sure, I'm talking about the short switch that turns the sidelights and dipped beam on.
There's a 'headlight loom' modification you can get which a) takes the power away from the switch and b) powers the lights directly from the back of the alternator which means you get full voltage at the lamps = brighter lights! I'd recommend this along with a new switch. It's an easy enough install to do.
On the wheel stalks. Aftermarket wheels/bosses might not have the prongs. When I fitted my Optimill boss it came with two roll pins which could be adjusted to properly engage with the indicator cancelling ring. From your pic it looks like these are mising. Perhaps a different pic would show the holes are there and you could fit roll pins or something similar? Dinnu is right, these prongs are part of the standard wheel.
The indicator/horn/dip stalk can definitely wear out too though, so that might also be an issue you have. Donald
in the past..
Post #921010 11th Sep 2021 11:40am
karlp606
I’ve got a mountney steering wheel with a mountney boss on and there’s a good inch gap between the boss and the blue circle thing, I’ll get the indicator cancelling ring ordered but will it reach between the boss and the blue circle :/
Post #921035 11th Sep 2021 3:50pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
On the subject of the relay, you can get a new pink relay which solves the problem (bypass) if you do not want to mess about with bits of wire. The stalks need replacing regularly, cheap enough from JGS. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #921041 11th Sep 2021 4:53pm
karlp606
Yeh thanks matey my relay has already been swapped out, I can see the little plastic surround where the headlight main beam is has started to melt away so looks like a bee headlight/indicator stalk to fix this problem
Post #921045 11th Sep 2021 5:02pm
