Home > Tdi > Seating the 300tdi crank shaft oil seal.
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I fitted a timing belt to my 300tdi but it has started leaking oil from the wading plug hole in the timing cover. I assume the oil seal has gone in badly so need to do it again this weekend.
Could some of you experienced folk give me tips on the best method to seat them so as not to have this happen again.
I have the crank pulley that came off if this is any use to help seat it.
Thanks for your help.
Mick
Post #920858 10th Sep 2021 2:33pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Did you fit the o-ring between pulley and crankshaft?
Post #920962 11th Sep 2021 7:47am
Mossberg
Yes, o ring fitted.
Post #920971 11th Sep 2021 8:23am
Ohlins
France
Good morning
I use three threaded bars screwed into the seal mounting engine block holes ( at 12 o'clock position and lower bottom left and right) and use this as a guide to slide the seal on so it arrives at a perpendicular angle to the crankshaft......the protection seal pops off ..........it also wouldn't do any harm to add silicon gasket seal........ It should be slid on dry also.
As an aside I wouldn't discount the leak coming from the camshaft seal also.
If high kms then if there's movement in the big end bearings the seal could leak too.
All the best
Smile Army 110 3 Door 200tdi
Army 110 3 Door V8
Army Lightweight 2.25 Petrol
110 300tdi 5 door
Yamaha XT660Z Ténéré
Gas Gas 300EC Ohlins
Post #926157 18th Oct 2021 8:40am
I Like Old Skool
@Ohlins
Are you getting mixed up with the rear main seal? The front pulley/crank oil seal is just a round drift in type seal.
Post #926172 18th Oct 2021 11:11am
Ohlins
France
Yes.......I'm a donkeyhead........
eeeeeee........or
I obviously need to order this............
Rolling with laughter Army 110 3 Door 200tdi
Army 110 3 Door V8
110 300tdi 5 door
Post #926332 19th Oct 2021 10:12am
