Home > Maintenance & Modifications > Wobbly headlight
NickMSM
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Wobbly headlight
One of my Speaker headlights is wobbling, noticed it the other night as I thought the unit was flickering before I checked. I haven't had a chance to check things since - does anyone have an idea what might be wrong please? I assume I may need a new frame/bowl? Not got the chance to check until the weekend.
Post #920678 9th Sep 2021 11:26am
dorsetsmith
Find out witch headlight wobbly one or both remove headlamp finisher check head lamp bezel have all three head lamp fixing clips and screw in place and all three screws are screw home as this holds headlight in to bezel
also make shore that bezel is fix with one screw to headlamp body ( this is plastic moulding in-between bezel and wing ) two more screw should be slotted in to the bezel these are the adjustment screw up and down side to side try not to adjust then
also check that your speaker head light have no loss parts inside
you may find that bezel has rusted and fixing broken off
the video is good
Post #920685 9th Sep 2021 12:19pm
NickMSM
Many thanks - Just had a chance to have a look at it, turns out the top adjustment (12 o'clock) on the body is threaded so the screw is pulling through. New body ordered Cool
Post #920844 10th Sep 2021 12:33pm
