Home > Maintenance & Modifications > Where do you install your battery monitors? Pics?
Landymatt
Hi,
If you have a twin battery setup, where have you good folk installed your battery monitors, and has it worked for you? Any photos?
I'm thinking we won't need to monitor while we're driving, but also wouldn't want to have to open seat box either.
I read on here a suggestion of side of cubby and the dash, but not seen any photos.
Cheers,
Matt
Post #920572 8th Sep 2021 8:02pm
BRUNEL1
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Fuji White
Rear load area?
Post #920580 8th Sep 2021 8:26pm
miker
My twin battery setup is a Victron Cryix volt sensing really, so very much at the simple end of the scale. I have a cheapy panel mount voltmeter in the dash that I use to check on the starter and the leisure.
Post #920614 8th Sep 2021 9:51pm
I've got a simple volt meter on a push-to-make button in the rear of my 110 to check the state of the second battery. I don't see the point in monitoring whilst driving either.
More details here: https://www.defender2.net/forum/post723236.html#723236 Darren
Post #920637 9th Sep 2021 7:14am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I have the NL battery controller mounted horizontally on the lower front side of the cubby box. Wire routes to the back and into the seat box where the relay is.
sorry no photo yet Smile
Post #921621 15th Sep 2021 6:22pm
Landymatt
Cheers - dead interested to see what it looks like as I should have the same monitor going in in next couple of days!
Post #921624 15th Sep 2021 6:44pm
macfrank
Here‘sa quick one (LHD driver‘s side). Forgot to say the cubby is raised due to a heater underneath. Not sure how it‘ll work without.
I found this position ideal because I don‘t like having too many dials etc in view (even if switched off) but if needed I can still look at it while driving. I found this is not a device you need to see or operate very often. It‘s also accessible while camping, either through the door or from the back.
Post #921633 15th Sep 2021 7:23pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
I have the HBC BM2000 with a Cyrix-ct and chose not to mount it. The cable is quite long. It usually stays in the cubby out of site but when I am using accessories more intensively (like the fridge in summer) I leave it next to the seat where I can see it.
 Roaming around 🇳🇴🇨🇭
Post #921684 16th Sep 2021 8:58am
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
Brodit clip
Post #921687 16th Sep 2021 9:50am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Side of cubby
Post #921983 19th Sep 2021 1:30pm
geobloke
Re: Where do you install your battery monitors? Pics?
Landymatt wrote:
Hi,
Cheers,
Matt
I am thinking of a monitor myself, mostly because I work a lot out of my Defender and charge batteries and an inverter from my second battery. So I am thinking about a Victron Smart meter BMV-712;
https://www.victronenergy.com/battery-monitors/bmv-712-smart
The benefit would be being bale to check the batteries on my phone without having to mount the gauge somewhere really obvious.
Best I have found that would be convenient and do the job well.
Post #921987 19th Sep 2021 2:00pm
