![]() | Home > Maintenance & Modifications > Best R380 Full Carpet Replacement Set.... |
big ives Member Since: 24 Dec 2013 Location: Northern Ireland Posts: 128 ![]() ![]() |
i used the Exmoor trim one in the front of my landy, excellent fit, looks very good and appears to be long lasting 2016 Discovery 4
1989 90 CSW V8 (fully rebuilt and running like a dream) 1996 defender tray back fully rebuilt/loaded for challenge events |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 302 ![]() ![]() ![]() |
Just watched the Exmoor fitting video actually on youtube, looks very nice and good quality, 5mm thick as well so with the silent coat under neath will certainly help with sound and heat insulation.
Just ordered these also https://www.ebay.co.uk/itm/324030541976?mk...jbEALw_wcB Presume for fitting you just drill through the sill and attached with screws? |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 296 ![]() ![]() |
Another vote for the exmoor carpet set. Bought one for my 1999 csw, though there is a bit of trimming involved around the gearbox tunnel and seatbox. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
Did you guys get the premium one -just seen it takes 5-10 weeks for delivery
Just ordered from Bearmach theyve got them in stock.
Rich1968 Member Since: 03 Nov 2013 Location: Towcester Posts: 85 ![]() ![]() |
Do the carpet sets fit ok with silent coat or similar underneath?
Thanks Rich |
It says on Exmoors website only to use uptown 5mm of insulation underneath, anything over 5mm could cause fitting issues.
From memory it was - bulkhead / gearbox tunnel I just used silent coat along with the original insulation, seatbox was just the silent coat, but everywhere else was the silent coat plus closed cell foam then the carpet, which was the premium exmoor version.
I think the worse pieces I found to do was the seatbox as that had to be cut to fit the corners. 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
Mine arrives today
![]() Just awaiting some more silent coat to arrive as well, thats my weekend sorted ![]() Need to get some new ratchet spanners also for the old pig seat bolts. |
landroversofstockbridge Member Since: 12 Jul 2018 Location: Hampshire Posts: 66 ![]() ![]() ![]() |
I’ve just ordered up the premium set from Exmoor, hopeful it arrives for winter, need some extra warmth in the cab
Ah its a 15 week with them they told me at the moment.
Bearmach have about 10 in stock for the R380 gearbox, ordered mine yday comign today. |
