Home > Td5 > TD5 engine - Puma chassis swap
Page 2 of 2 <12
zakoos wrote:
The only thing that bugs me is a 10mm difference I found for this measure between the rails (63 vs 64cm). Is the Puma chassis supposed to be different?
The Puma chassis isn't supposed to be different. The difference you've noted is just typical of the tolerance in this and other areas and is nothing to worry about. Darren
Post #919732 3rd Sep 2021 6:19am
kenzle8a
I'd say a Defenders chassis is more a case of intolerances....
Post #919745 3rd Sep 2021 9:09am
dorsetsmith
providing chassis to body work mounting points line up i.e. bulkhead out rigger (15 , 16 ) 750mm centre line of the chassis out to the fixing bush both side. test fitting body parts will be Order the day and save time in long run
to quote local land rover specialist test fitting body parts as will not fit ever if it did some time on the past from the same defender
Post #919757 3rd Sep 2021 9:53am
Dinnu
Out of curiosity, I measured MY88 chassis, 3cm further front of the front crossmember, and measured it at 635mm
However my 90 came with 1 washer on left side, between bulkhead and its outrigger, and 2 washer on the right side from the factory.
Measuring between bulkhead outrigger and tubular tub outrigger confirmed the need of the extra washer on the right side. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #919781 3rd Sep 2021 12:51pm
zakoos
France 2001 Defender 110 Td5 DCPU Baltic Blue
Hi there!
Bumping this thread as we managed to reweld Dixon's mounts to the Puma chassis.
Happy to report that everything is lining up properly! The TD5 engine is in, some adaptation work required for the radiator mounts but apart from that, all good.
Many thanks for everyone's help Thumbs Up
Post #927222 26th Oct 2021 5:16pm
dorsetsmith
Thumbs Up
Post #927225 26th Oct 2021 5:23pm
NickMc
You have Tdci (2.4 variant I think, hard to tell from the picture) chassis and mounts and they’re not the same as Td5 mounts they a different shape and profile. Just did this conversion today and I’ve done it many times. The gearbox mounts are different too.
I set the chassis up level and then set each mount with a magnetic clamp at 4 degrees with an electronic inclinometer tack each one on and test fit.
Post #933935 17th Dec 2021 12:15am
NickMc
They are different in lots of little ways. Even the 2.4 and 2.2 have differences.
Post #933938 17th Dec 2021 12:17am
Dinnu
On a 2.4 and 2.2 90, the handbrake is hanging lower than the bottom of the chassis rail, where as on a Td5 90, you cannot see the handbrake drum when viewing from the side of the chassis. Transfer box mountings look identical, so I suspect it is a matter of the chassis TC mounting brackets welded lower on the later Defenders 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #933946 17th Dec 2021 6:52am
I'm sure they are but I doubt that a 10mm difference in the distance between the chassis rails is one of them. Darren
Post #933949 17th Dec 2021 7:43am
Page 2 of 2 <12
