![]() | Home > Puma (Tdci) > First proper inspection and first leak question |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2546
While you are waiting for Haynes, have a look at the real thing https://onedrive.live.com/?authkey=%21ALkd...9C85C7C171
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3652
Difficult to trace an oil leak once the oil has contaminated everything.
Best is to have it washed and dried. Assuming leak is from engine, start the engine, and see where the oil appears first. If there is no oil leak, take it for a very short spin, and then check again. Smelling the oil might help determine if it is engine oil, or diesel fuel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| jonesie Member Since: 25 Sep 2011 Location: Petworth Posts: 231
Hi Rivarama,
Have you seen any oil leaking from the top of the engine, under the plastic covers etc? Jonesie Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
| Rivarama Member Since: 28 Aug 2021 Location: London Posts: 155
Hi Jonesie.
I had a look and the top of the engine has quite of bit of oil. Could it be the rocker cover seal that’s gone? The car only has 40k miles… feels early to pack up no? Also, having wiped the gearbox and sump last night to see where the leak came from, it now looks like the gearbox has a slight leak too. Is there a way to check gearbox oil level/top it up like in the old series? Can seem to find it in the manual. Thanks |
https://www.defender2.net/forum/topic8707.html
Should answer the gearbox oil volume question. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Welcome to defender2 and Defender ownership
Sorry I haven’t replied earlier.
Sounds like it could be injector oil seals… Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
Thanks for your input guys, spot on.
A couple of injectors seals were indeed shot. The injectors were full of gunk that had accumulated overtime as a result. I have no idea how the MOT missed that leak… anyway, all cleaned out now. The rust on the fuel rail got sorted and everything is now back in and not leaking. The cam cover gasket was changed by the same token as it was a bit wet. All seems dry for now. The engine needs a good clean now w degreaser and some light running water and I will inspect the rest this week. |
Glad you have sorted it.
The seals don’t seem to last more than 40,000 ish miles and if you use your right foot they last even less. Think you’ll be fine now. Good luck. Jonesie Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
| All times are GMT |
