Home > Maintenance & Modifications > Hinge bulkhead no-longer captive nut - any ideas? SOLVED
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Finally got round to changing the hinges on my front passenger door today... Top one went swimmingly...
Bottom one though I have one captive nut that has broken free of it's cage and is just spinning on the old bolt.
It loosened about 3mm before it went, so I can get a trim prising tool in between the hinge and the rubber to force nut up against the cage, but even this isn't increasing friction enough to get the bolt to turn in the nut.
For now I'm smothering it in WD40, and Ive got reasonable access to the hole, so I can get a screw drvier in against the nut, but again not enough to stop the nut turning.
I could* cut the bolt, but I think that won't improve the situation as it'll still be stuck in the hole with a nut on the other side.
I'm guessing others have had to deal with this?
Now in situation where I can't really just bolt it back on again and drive round with a bolt loose
*this might be optimistic without damaging bodywork
Post #918885 27th Aug 2021 6:19pm
Dinnu
Congratulations, you just made it theft proof Laughing
You can cut it, extreme care that you di not damage the bulkhead. Keep the blade on the hinge side, as hinge is cheap to replace if damaged. Since the nut in the captive plate is spinning, most likely you would then be able to push what remains of the bolt and the nut in and then take it out from the central rectangular hole. Then again care not to drop the bolt/nut in the bulkhead. Maybe you can tie some cable ties on the bolt, right next to the bulkhead before you start cutting, so you can keep or pull the bolt out. The cable tie might act as an extra protection to the bulkhead. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #918889 27th Aug 2021 6:38pm
balmybaldwin
That's what I fear.
After a bit of poking about I think there is a side access that could be used if I take the wing off... however I forsee that leading to similar issues elsewhere.
One of my issues is that the hinge is so loose it might be hard to cut without someone holding on to it... I guess I could fix it with the other bolt.
Might have to go shopping for a low profile grinder... I doubt a dremel bit would do it, and my current grinder is difficult to get flat against things
Post #918891 27th Aug 2021 7:34pm
Drill the head off the bolt, remove the hinge, if necessary cut the bolt shorter, then bend the retaining tag clear of the bulkhead and remove the remains through the centre cut-out.
If you try cutting between the hinge and the body you will almost certainly damage something you don't want to damage.
If you can't drill the head because the bolt spins, use a 1mm cutting disk in an angle grinder to cut into the hinge parallel to the body panels and cut through the bolt (use a Torx tool to stop the bolt spinning). You'll wreck the hinge but you're replacing it anyway.
Post #918893 27th Aug 2021 7:39pm
nitram17
balmybaldwin wrote:
That's what I fear.
Have you tried heating up the bolt with a small burner and try wedging in a trim fir tree removing tool and see if it will turn?
Post #918900 27th Aug 2021 8:47pm
donmacn
balmybaldwin wrote:
That's what I fear.
I would suggest a set of left handed drill bits - they might just encourage the bolt to start turning.
But mainly I wanted to mention a diamond edged cutting disc I recently found/bought for my dremel - it was a really effective piece of kit. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #918905 27th Aug 2021 9:01pm
MichaelE
Whatever method you have success with, don't worry about dropping the remnants inside the bulkhead. Ultimately, no harm will be done in the big scheme of things if it stays there. When I was rustproofing the internals of my bulkhead last year I too lost a nutplate remnant. Down at the bottom there was a small hole, maybe half an inch or less. Can't remember if it was a drain hole or a rust hole. Anyway, I enlarged it to about 3/4 inch or so and let a pile of rust fall out, along with the remnant. Then I placed a bowl underneath to catch the excess Dinitrol that poured out after injection, to re-use.
When it comes to fitting new nut plates, there are one-piece ones available, and you won't have this trouble again. It's also worth noting that I had a new 2-piece nutplate [Britpart] come apart and drop to the bottom on trying to start the bolt. That's when I found the 1-piece ones.
Post #918931 28th Aug 2021 12:38am
balmybaldwin
Well, after some encouragement from your good selves, I have taken an Angle Grinder to my pride and joy.
Success!
Plus I thought for benefit of others, here's what I did to make sure I didn't drop the bolt and J clip
Finished:
Post #919041 28th Aug 2021 10:09pm
