Onboard air Mod , Viair 485c + 2 gallon tank - ext.output
Installed my Viair 485c aircompressor and 2 gallon tank in de back of the 90 ( Hardtop, Van, Commercial)
Used Flexilla 300psi hoses, professional crimped.
Did use a max 15 bar regulator between.
Made an external safety Quick coupler on de back.
Regulator set to 11.5 bar.
Compressor stops at 14 bar /200 psi, starts again when it drops under 165 psi
Carling HR switch dtdp, 40amp fuse, Direct to battery
Hose thru the rear vents, with a 90 degree fitting for connecting the safety coupler
Prevost S1 euro safety coupler ( max 12 bar)
When Offroad and going back to the road I can fill my airtank in advance,
So with aired down tires of 20 Psi refill of 4 tires to 34 Psi take just 5 minutes.No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
25th Aug 2021 10:44pm
Hairy Dan
That looks like a great solution and probably cheaper than the built in one Land Rover offers Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari Instagram @defender_v8
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
