Home > Puma (Tdci) > Intermittent starting problem
ewinter110
Italy
Hi all,
I’ve got a 2009 110 2.4 Puma. Had it’s fair share of issues and now I’ve got a new one! Been trawling the forum for some info but non of the issues quite match what I’ve got. Basically 9/10 times starts with no problems, but the other it all lights up as normal then when I go to start everything goes blank and no attempt of a start. Sometimes if I hold it there it’ll start after a couple of seconds, but most of the time it needs a few attempts then starts completely normally. Sometimes a wiggle of the key or turn off the AC if it’s on and it starts, hard to say if that’s it or if it’s just a bit of confirmation bias. I don’t want to go and replace the ignition barrel if there are some other avenues I can try first that aren’t as challenging. So far I’ve replaced the relays and I’ve given the end of the barrel a good clean and inspection.
Cheers in advance for any ideas!
Post #918367 23rd Aug 2021 6:51pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
ignition switch is where i would start. its on the end of the ignition barrel that the key goes in. Roaming around 🇳🇴🇨🇭
Post #918374 23rd Aug 2021 7:56pm
Yep, ignition switch. Darren
Post #918417 23rd Aug 2021 9:49pm
ewinter110
Italy
Given the ignition switch a good clean up with contact cleaner and made sure there aren’t any loose connections there. Time will tell if it was just a bad connection.
Post #918424 23rd Aug 2021 10:16pm
