Home > Maintenance & Modifications > Rear shocks
HenrikSw
Sweden
Rear shocks
I´m sure the topic been up before and some wise guy might be able to share a tread from before.
However I have a Defender 90 Td5 lifted 2" and need to replace the rear shocks, what do I buy?
In all honesty the off-road time is .......limited so mainly road (despite the lift... Rolling with laughter ).
Looking for something that work good and last, I intend to keep the car long.
Anything else I should change at the same time? Question
Post #918304 23rd Aug 2021 11:46am
geobloke
In my experience Old Man Emu +2" shocks are absolutely superb on and off road, I stand by this as I have them fitted to my Defender and have done for many years.
As far as what else to change at the same time... Well I would definitely check your anti roll bar ball joints and bushes whilst you are there. I have no idea what you have fitted at the moment but if they are anywhere near 10 years old I would be looking to replace them as a matter of course. Plus it makes such a huge difference to the ride...
Post #918305 23rd Aug 2021 11:53am
jst
lots of options on this and depends on budget and need.
i run 3 defenders. they all run OME shocks all round.
I have been down the Terra Firma, Koni, and King routes in the past.
OME last well, have lots of duty options to suit the need.
my 110 ones have been on over 8 years, used for towing, day to day and some off road tuition. std length Heavy Duty
pin/pin all round. rear recently changed to pin/pin. rears 1 year old. front 8 years old. some overlanding.
130 runs Heavy Duty OME all round, again pin/pin all round, used a off road camper, some towing and light off roading. 1year old
90, again pin/pin all round, 2 years old.
All 3 running standard LR suspension, 110 and 130 have rear helper bags.
i run Gywn Lewis rear top shock mounts to convert to pin/pin.
i find them good on roads, subtle enough with how my vehicles are loaded off road and robust with great damping and performance for the £££.
Gwyn Lewis would be worth a call to discuss suspension options. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #918324 23rd Aug 2021 2:39pm
geobloke
Just to add to James' recommendation. Gwyn is very knowledgable and good to chat and deal with... Thumbs Up
Post #918357 23rd Aug 2021 6:07pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
I have spoken with Gywn for shocks and as I don't tow apart from taking the caravan for its yearly service as we have it on a seasonal pitch or carry a lot of weight wolf wheel on the spare wheel carrier that's all really he recommended old man emu adventure Front shocks on the front and rear for comfort as we have the side facing seats which are used for the boy's but they feel every pot hole so knowing that it will never be Range Rover comfort if it helps them on long trips out the better for my ears from complaints.
They are being fitted as we speak so I will know next week on my 2005 TD5 90 so the same as yours but not lifted
Post #918438 23rd Aug 2021 11:19pm
HardCharger
On a related question, what's the advantage of converting the rears to pin / pin over standard?
Post #918443 24th Aug 2021 4:25am
HenrikSw
Sweden
Thanks all for good advice! Thumbs Up
I will take a call with Gwen and hopefully find a good solution, with him.
Post #918472 24th Aug 2021 9:00am
geobloke
The ring mount at the top of the rear shocks are a known weak point. Converting to pin/pin reduces the risk of breaking a shock absorber.
Converting to Gwyns rear mount will also allow you to upgrade to a +5" shock should you ever want to. This is also a great modification and I miss having it installed on my 110.
Post #918488 24th Aug 2021 10:00am
geobloke
Obviously it is a typo, however... Calling a Welshman Gwen, when his name is Gwyn, may not impress him much... Wink
Post #918489 24th Aug 2021 10:01am
HenrikSw
Sweden
Sorry!!!! Embarassed Bow down
Post #918547 24th Aug 2021 3:12pm
jst
An eye at the top can limit axle arc movement on articulations creating stresses that result in premature failure. Same as if the eye is done uo too tight or the washer is incorrectly fitted. A pin at the top allows greater flexibility without the stress Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #918576 24th Aug 2021 8:36pm
keith
I’ll second that. Very nice to talk to. 👍
Post #918587 24th Aug 2021 9:47pm
HardCharger
Thanks! Thumbs Up
Post #918617 25th Aug 2021 4:20am
Bluest
My friend converted to pin/pin on the rear so he only had to carry one spare to cover all 4 corners when travelling. 2007 110 TDCi Station Wagon XS
Post #918628 25th Aug 2021 8:05am
geobloke
That's a great overloading remote driving tip that Thumbs Up
Post #918637 25th Aug 2021 9:21am
