Home > Td5 > Headlight voltage
excossack
Headlight voltage
While changing the headlight bulbs yesterday, i took the opportunity to measure the voltage.
Engine running, no bulbs connected and light switch at position 2.
14.3v
Engine running, no bulbs connected and light switch at position 2 & bulbs connected,
10.3v
Would this be the expected results, 55w bulb causing voltage drop along the wires and switch? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #917913 20th Aug 2021 9:15am
rallysteve
As you have seen, you only get volt drop when current flows (V=IxR). That volt drop is far too high though, should only be a volt maximum really.
Probably the first signs of switch failure (assuming you dont have relays fitted)
Post #917916 20th Aug 2021 9:30am
geobloke
That looks about normal for voltage drop with H4 bulbs on elderly wiring. This is why changing to LED headlights is such a good idea, so much less current draw on the fragile (and usually aged) Land Rover wiring loom and pathetic light switch. The older the loom gets, the less efficiently it will work, less voltage to the bulbs, increased resistance, more heat and melted switches. The other option is fitting the standalone headlight loom (such as the one by Red Bison) that uses the standard lighting loom to trigger the standalone loom that is connected directly to the battery. Protection for the Defenders loom, plus better light output. Better all round.
Post #917919 20th Aug 2021 9:34am
excossack
Cheers both, suspected as much. I have since purchased an headlight loom but not fitted yet.
I wonder how much light I am losing....? 1999 Defender TD5 110
Regards
John M0VAZ
Post #917923 20th Aug 2021 9:46am
geobloke
A noticeable amount... Shocked When I stuck the loom in with H4s it felt like night and day at the time. Then I stuck LED headlights in and it was like turning daytime on...
Post #917924 20th Aug 2021 9:54am
excossack
So an noticeable amount then. There are times down country lanes and unlit motorways when I wonder if my lights are actually on....
Another job to add to the list before winter 1999 Defender TD5 110
Regards
John M0VAZ
Post #917926 20th Aug 2021 10:00am
geobloke
Definitely before Winter. If you don't already have them then also think about fitting the clear crystal lensed headlamps as well. Big difference on the standard LR/Wipac quadraphotic items.
https://www.paddockspares.com/pm935-wipac-...ralia.html - Obviously there are other sellers, but you get the idea Smile
Not that expensive, but worth it come winter and country roads Thumbs Up
Post #917932 20th Aug 2021 10:28am
excossack
Cheers, yup got them with Osram Night breakers. Just going from old headlights to new, was quite a change. 1999 Defender TD5 110
Regards
John M0VAZ
Post #917934 20th Aug 2021 10:34am
geobloke
Great combo the Crystals and Osrams Thumbs Up Thumbs Up
Post #917943 20th Aug 2021 10:53am
excossack
They are indeed. Hopefully get the loom done over the next couple of weeks. 1999 Defender TD5 110
Regards
John M0VAZ
Post #917944 20th Aug 2021 10:55am
jst
The switch has high voltage drop well worth running through relays. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #918073 20th Aug 2021 11:57pm
excossack
Hi JST. Thats the plan, I have the loom, just need to get around to fitting it. 1999 Defender TD5 110
Regards
John M0VAZ
Post #918080 21st Aug 2021 8:15am
jst
i run relays on my defenders having had a switch melt a while back started the process. voltages all much higher than the 10.5ish std. even with std bulbs difference is seen, add better bulbs and its a cheap good mod without need to LEDs etc etc Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #918081 21st Aug 2021 8:43am
dorsetsmith
Remove head and side lighting fuse before starting Exclamation
You will need to remove dash front and also two plastic covers in-between steering wheel and dash to get to plug switch lighting
you can mod the head light cct to add relay with out cutting in to wiring c0041 - 4 and c0041-1 have to be removed from plug switch lighting
parts needed from mod
Hard plastic 6.3mm female blade terminal cover. White qty 10
Thin wall cable 2.0mm. blue ---------- brown/ blue 2m of each ---------black 500mm long
Tin plated 6.3mm male terminal with latch 1.5-2.5m cable. qty 2
Single cover for 6.3mm male blade terminal. White. qty 2
5mm ring terminal qty 1
6.3mm female blade 1.5-2.5mm qty 10
6.3mm female blade 4mm qty -1 relay end for the two brown- blue wires that are grumped as one see pic
This pic show lighting switch end with two 6.3mm male terminal with covers that join up with two wire removed from the plug you will need too add female covers to the removed wire ends from the plug also shows the two female terminals that fit in to the plug no cover needed
480mm 16mm conduit to cover wiring between relay and terminal see below pic one
30 amp automotive relay with mounting tab
I have the relay mounted under dash on right hand side and black wire and ring under fixing screw
U = blue
NU = brown blue
b= black wire go to ground
R = 5mm ring terminal
M= Tin plated 6.3mm male terminal with latch 1.5-2.5m cable with
Fm = 6.3mm female blade only so that way can be fitted into plug that wires c0041 - 4 and c0041-1 removed from
6.3mm female blade with Hard plastic 6.3mm female blade terminal cover. White used at relay wire ends
check your wire and replace fuse and test side and head lights
Post #918089 21st Aug 2021 9:46am
