![]() | Home > Maintenance & Modifications > Caliper bolts question - getting into them!!! |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3585 ![]() ![]() ![]() |
Can use a ring spanner? Get the ring of another spanner into the open end side to increase leverage. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 361 ![]() ![]() ![]() |
Worth a shot - thanks Dinnu!
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8324 ![]() ![]() ![]() |
3/8 short socket Cheers
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17859 ![]() ![]() ![]() |
I don't recall what tools I use for this job but have never had any difficulties. Are you using 1/2" square drive socketry? If so, as jst suggests try 3/8" drive (it is rare that I ever use 1/2" drive). I seem to recall that a shallow 3/8" drive socket and slim ratchet fits straight on, and a 3/8" drive socket with the appropriate extension can pass the spring and come out behind.
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1887 ![]() ![]() |
I think I also used a 350mm 3/8 breaker bar, and turned the wheel to move it slightly away from the spring. Those guys can be tight in there. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
I was using 1/2” hence the issue. Got a wee socket on there this morning, fitted like a glove and I’ve rounded the bloody thing off. So I’m really screwed now. Why oh why do I bother!
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
Are you using a 6 or 12 point socket? The caliper bolts have a 12 point head. If you are using a 6 point socket then it will be driving across the points of the head and easy to slip. Try a 12 point socket which will drive on the V's of the bolt head
![]() > 110 XS Double Cab |
![]() If the worst comes to the worse, then all I would say is.... Cobalt drill bits. I used them recently to remove a rounded cylinder head bolt on a V8. First time I'd used cobalt and was amazed at the difference. They are expensive, but worthwhile. If you started with a 3mm, then up to a 6mm, then a 9 or 10mm that would do the job. You would only need to drill the head of the bolt enough to pull the caliper off - i.e. you wouldn't have to drill all the way down into the shank of the bolt. Once the tension is off the bolt, the rest should come out easily, though as those are threadlocked they may still put up a fight. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Yeah I got 12 point socket after seeing a few posts. Still rounded. I’ve stuck the pads back in and taking car to a professional to get the work done. Defeat well and truly admitted! Thanks for the advice chaps. I’m just a hamfisted dolt!
Not at all.
I have to say, whenever I do this job I always offer up a wee prayer just in case it goes wrong. The bolt rounding is precisely the thing I always hope to avoid. I think I've just been lucky so far! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
The only problem with this is you'd probably need to take the axle off the vehicle first to get access ![]() Other options might include cutting or grinding the head off so that the caliper can be removed, after this the disc can come off and the "other end" of bolt becomes accessible, or welding something to the damaged head of the bolt so that it can be gripped. |
I'm not near my car at the moment to take a sense check, but I thought, if you put the wheels on full lock that you'd get into the bolts with a drill? I'd imagine that getting in with a grinder would be even more difficult? This demonstrates why I always offer up my wee prayer for the damn things to turn! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Problem is that the OPs caliper is on the rear axle, not the front axle.
He does not say if it is a 90 or 110, but I know the 90 is more limited space wise... I do not know if there is enough space due to the fuel tank brackets. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Doh!!
My mistake. Should have read that more carefully. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
