Home > Series Land Rovers > Leaf springs.....
kipperthedog
Leaf springs.....
Leaf springs are a bit of an unknown quantity for me so I'd be interested in, and grateful for, the views of those with experince.
My Series 3 88" truck cab sit 1" lower on the offside than the near side. It has parbolic springs of unknown make but of the style of the current Britpart "santana" type springs. These make it sit 1" higher approx. than standard leaf springs on the offside and 2" higher on the nearside, as far as I can work out form the LR workshop manual.
I am assuming that this 1" differnce is made up of a 1/2" lower offside and a corresponding 1/2" (ish) higher nearside resulting. Which actually isn't a very big "sag".
The previuos owner had concluded that new front springs where required and it came with a new set of Britpart para's, unfitted. However these are very tall...8" from ground to apex when inverted, so I have a feeling that fitting these MIGHT level out the front but leave it sitting higher and give me a new problem of higher front than back.(They are not handed spings.)
I am wondeing whether slackening off all the shackle bolts and settling it before retightening may be enough to acheive at least a reduction in the difference?
I hope this makes some sort of sense!
TIA.
Post #917443 17th Aug 2021 6:33pm
gcc130
Try it and find out...
Post #917446 17th Aug 2021 6:54pm
A leaf-sprung Land-Rover should when unladen and static sit higher on the o/s than the n/s.
Post #917451 17th Aug 2021 7:55pm
kipperthedog
So it isn't totally out of the question that the springs fitted could be handed and the wrong way round....
Post #917455 17th Aug 2021 8:10pm
Grouse
We had two Series 3’s both bought brand new in 1973, a 109 Station Wagon and an 88” Hard Top. Neither of them showed any visible difference when stationary and empty in ride height. 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #917499 18th Aug 2021 6:09am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Unfortunately not all parabolic springs are equal, some of the cheaper versions can sit the height quite high while others can make the vehicle lop sided. I fitted some GME springs to my 109 last year and the ride height is excellent with no lean to the left or right.
Post #917523 18th Aug 2021 10:10am
Philip
GME parabolics from Paddock were noticeably lopsided at the front on my six cylinder - loosening the shackles and letting it settle improved but didn’t fix it.
Post #917526 18th Aug 2021 11:51am
