Home > Modifications & Maintenance (L663) > BREMBO 6-Pot Brake Upgrade
Page 2 of 5 <12345>
AndrewS
jackie wrote:
Sorry to hijack this thread….
I am thinking to go for D250. However, since it comes with 2-piston caliper with 349mm disc. I don’t know if it is sufficient to stop the 2.4tonnes defender. So, for existing D200/D250 owners, can you advise if the stock brake is good or I shall opt for D300 which has 4-piston caliper instead?
Thanks
The standard brakes are very good. I have a 110 300 hard top and a 110 X with the bigger brakes. There is no obvious difference between them under normal braking conditions. In fact I'd say that there is no point upgrading unless you simply like the look of the bigger calipers. 130's have feeling's as well you know Smile
Post #916645 13th Aug 2021 12:06am
thepetrolhead
United Kingdom 2003 Defender 90 Td5 CSW Oslo Blue
For the looks....
Agree standard brakes are fine. Had my 90 HT three weeks and the brakes are perfect! I'd only be upgrading for the looks only. Like the look of the 6 pots, especially the V8 'blue / turquoise' ones.
Post #918118 21st Aug 2021 3:17pm
Cedric74
Belgium
Hi everyone,
Is there right there is two size of 6 pot caliper?
D300 X dynamic smaller than the X (who has the same size than the V8 )
Thx
Cédric
Post #919006 28th Aug 2021 3:24pm
Cedric74
Belgium
Anybody ???
Post #919711 2nd Sep 2021 7:50pm
thepetrolhead
I believe the 6 pots are all the same, just different colours!
Post #919788 3rd Sep 2021 1:39pm
Cedric74
Belgium
Thanks!
Someone know the oem parts numbers or the Brembo reference ?
Post #919790 3rd Sep 2021 1:46pm
thepetrolhead
On page 1.
Post #919836 3rd Sep 2021 6:47pm
Cedric74
Belgium
Only need caliper, brake pads and disc?
Do you know a shop who sell those brembo parts ?
Post #919878 3rd Sep 2021 9:46pm
thepetrolhead
Re: For the looks....
Noticed plenty of firms doing the upgrades now. Need minimum 20" alloys. Part numbers in previous posts.
https://vulkanautomotive.com/products/defe...f4EALw_wcB
Post #934090 18th Dec 2021 11:38am
mmbanf
Italy
Upgrade Brembo 20”
Hi all, I'm joining this discussion.
I'm Marco, happy owner of a 90, d200, 3.0 d, the car has 26000km and everything is fine, however, reading about front disc deformation problems and seeing that the front calipers are not very attractive, I decided to upgrade the front braking system (for the moment ).
The front braking system from chassis M2000001 is composed as follows, front suspension arm equal for all types of brakes, also looking at the discovery V model, all three types of brake (18,19,20") were installed on the same front arm.
as a demonstration of this same size of the discs and calipers, I also consulted this Brembo table where it can be seen that the thickness/height of the discs is the same on the three types.
However, there is a difference in the systems....
the hub/wheel bearing on the 20" system is different.
however, since the overall dimensions are the same, I think it is a more robust wheel bearing, but not with a different overall size, also because otherwise it would change the track of the car.
well! Now I concentrated on the caliper, there are two types of caliper with 380mm discs, the one I like is the 6 piston Brembo caliper. I took the code of the blue one as a reference,
another thing to consider is the sheet metal protection of the disc, on groupsets 18 it is different from the 19.20", so you have to either replace it or modify it by cutting a rear piece. You also need new caliper bolts, a wear sensor, and two protections on the axle shaft.
I was lucky, I found two almost new six-piston Brembo calipers, disassembled from a new Range Rover Sport L494, as the customer wanted them red.
I bought the original Brembo brake pads (huge!) and now I'm waiting for the 380 mm Brembo discs to arrive.
I will soon try to take several photographs when I proceed with the installation, if anyone has any advice for me they are very welcome!
Hello everybody.
Marco
Post #973359 4th Dec 2022 11:52am
thepetrolhead
As an update:.
Upgraded my front brakes a while back. Now running genuine Brembo 6-Pots - Xenon Blue V8 calipers. My alloys - 20" 5098s Satin Grey.
Easy and simple brake upgrade.
Post #973380 4th Dec 2022 4:20pm
mmbanf
Italy
Brembo upgrade
compliments!!!!
your brake calipers are beautiful....
I only found them black...but on my white car they should be nice!
give me some information, the braking is improved or the same, the feeling on the brake pedal the same?
I'm participating in the beta test with gap on the id tool, I saw a possibility of modifying the CCF on the front and rear brakes, with an indication of the type of system (18,19,20), I think it acts on the abs pump and brake distributor, you did you change anything? thank you. Marco
Post #973385 4th Dec 2022 5:48pm
thepetrolhead
No difference in brake feel, but suspect stopping distance will be improved, but don't drive fast enough to notice a difference. For me it was more for the look. As I said before the original 4 pots are good brakes.
I note 4-pots still used on D250 with 20" wheel option, but have noticed they fit 6-pots on D250s if you go for 22" wheel option.
Post #973394 4th Dec 2022 6:50pm
OldDD
Isle Of Man 2012 Defender 90 Puma 2.2 HT Orkney Grey
Did you buy the kit from Vulkan?
I am told there is a spacer and spiggot kit required to make the larger brakes fit so not simple plug and play...
Post #973814 7th Dec 2022 5:04pm
thepetrolhead
PM sent.
Post #973841 7th Dec 2022 9:18pm
Page 2 of 5 <12345>
