Home > In Car Electronics > New battery does not go into trickle mode with Ctek |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Internet reading suggests it may need up to 10 days on stage 7 before going to stage 8
25th Jul 2021 7:51am |
Doesn't sound like a problem - Stage 7 is "Fully Charged".
Stage 8 is just gives a pulse when necessary to keep the battery fully charged - it may well be doing it and then dropping back to Stage 7 whilst you are not watching. |
25th Jul 2021 9:27am |
Thanks Supacat
25th Jul 2021 10:23pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 389 |
Oddly I find that my Yuasa batteries often seem to be 'stuck' on Stage 4 while they are in the vehicle. I wondered if it was the slight current drain (25ma) from the Lodar remote receiver, clock etc, that just keeps the voltage slightly down and fools the charger. When you check it with a meter the battery sits at 14.8V on the charger. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
27th Jul 2021 10:09am |
Don't measure the battery voltage with the charger on - it is bound to be high.
Disconnect charger and wait a little while then check voltage at battery. Should be about 12.7V or little more. Mine was 12.9V fully charged. |
28th Jul 2021 9:48pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
Mos 5 is only just man enough for that battery too. I’ve got a mxs10 for 110ah
29th Jul 2021 9:30am |
Yes I know that, what I meant was that the slight drain from the 'sleeping' demand might fool the charger by not quite allowing either the voltage to get up to expected level, or the current input to drop to a low enough level for it to deem the battery to be full. Mine all sit at 12.8-12.9 if full and in good condition. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
8th Aug 2021 11:04am |
10th Aug 2021 1:40pm |
