![]() | Home > Td5 > TD5 cold start - fuel pump? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
I know you say you’ve done the injector seals, but that is exactly what you are describing. Possibly not what you want to hear. Can’t help with pump question.
fondelli Member Since: 21 Jul 2017 Location: northern ireland Posts: 15 ![]() ![]() ![]() |
Less than 10k miles ago it had a replacement head, so seals were replaced as part of that process
check your filter head and duck bill nonreturn valve and air bleed fitting
![]() ![]() both items have been re call in the past for poor starting if you can place clear pipe in the fuel return line in between fuel cooler and tank engine end and check for air in the fuel But your pump may be noisy du the air Last edited by dorsetsmith on 4th Aug 2021 4:46pm. Edited 2 times in total |
AT1963 Member Since: 08 Jul 2020 Location: Leicestershire Posts: 148 ![]() ![]() ![]() |
Sounds like injectors. Had mine done with oem injector seals and these lasted 6/12 so had genuine replacements with no problems.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
My genuine seals only last around 24months. Ironically had to use some britpart ones i had as i couldnt wait for delivery and they lasted longer!
The genuine ones are ridiculous price now! 02' 110 TD5 Double Cab Rebuild Thread |
Thanks all- sounds like injector seals
