![]() | Home > Technical > Defender 90 TD5 fuel pump |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Different fuel float arm/level to account for the different tank shapes i believe.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 406 ![]() ![]() |
As said above the tanks are different sized and shapes, I believe that you can swap the floats over though.
If you’re doing the job, make sure you get a genuine pump and not a cheap aftermarket one, it will save you doing the job multiple times. Also worth getting a new locking ring as well as they are normally rusty and a pain to get off in one piece. |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 983 ![]() ![]() ![]() |
I was going to go for a Bearmach pump. Are these not good?
Jim |
AT1963 Member Since: 08 Jul 2020 Location: Leicestershire Posts: 148 ![]() ![]() ![]() |
Lots of people suggest only using genuine pump.
Not sure exactly why but likely to be with quality and durability. Had mine replaced 4 months ago with genuine ![]() |
From experience the aftermarket ones are very noisy and don’t last very long, but a genuine Vdo siemens unit is probably 3 or 4 times the price of a Bearmach or britpart one
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Discovery ones used to be even cheaper than defender.... and you can just unclip the arm and swap over.
