![]() | Home > Puma (Tdci) > Dual mass flywheel |
no, but the TD5 had them 2.4 90 XS
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
I wish the puma had a dual mass flywheel, as it's the harshness transmitted through to the gearbox which accelerates wear. A double edged sword scenario if ever there was one!
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
What wears out? engine, clutch? Puma 110" SW ............................................................. Earth first. Other planets later |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
I see a market gap for you to exploit ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Sorry, I was referring to the gearbox. |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
If this is the engine from a transit surely a DMF from that would fit if you really wanted one? Not sure if they're the same size but i bet they'd be close. |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
Did not have a look at it, but thought it would have a dmf and the smf was for hd usage? Never forget: cars have owner, Landrover have field service personnel.
Are all inpout&output shafts really "loosen" in these gearboxes? (radial slack) Puma 110" SW ............................................................. Earth first. Other planets later |
jamesc Member Since: 19 Nov 2010 Location: Elsewhere Posts: 74 ![]() ![]() ![]() |
[I wish the puma had a dual mass flywheel, as it's the harshness transmitted through to the gearbox which accelerates wear. A double edged sword scenario if ever there was one!]
So if we want a Puma to go 150,000 miles should we be looking for a different (better) gearbox to mate with the engine? |
Sorry - I obviously haven't got the hang of this 'quoting' lark!
The Getrag MT82 gearbox is an ongoing tragedy - just try looking at some of the Mustang owners' forums too... |
