![]() | Home > In Car Electronics > FM aerial |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4337 ![]() ![]() ![]() |
I can’t say I’ve ever given the appearance of the aerial a 2nd thought. I do lower it when off road to stop it getting snapped off by trees though. Nakatanenga do an alternative style one. 4x4 Overlander sell it. 2007 110 TDCi Station Wagon XS
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 ![]() ![]() ![]() |
I would thoroughly recommend the Nakatanenga aerial.
Top tip, remove the panel on the top of the wing when you come to switch it over. 2011 CSW XS 90 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20999 ![]() ![]() |
I have the Nakatanega one, no complaints from me. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 344 ![]() ![]() ![]() |
I like the crappy standard aerial.
Set it to the height of the vehicle. Hey it checks the height when going under height restriction barriers ![]() |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 176 ![]() ![]() ![]() |
I shall have a look at the naka-jobbie.
Also like your height restriction warning too! |
MichaelE Member Since: 18 Jan 2020 Location: Crawley West Sussex Posts: 155 ![]() ![]() |
When I had to chop my old aerial off the wing , first I couldn't find a suitable replacement that wasn't a stupid price, and second I didn't want the hassle of feeding the cable through. I had just fitted a heated screen and didn't want reception problems with a stick on aerial. As I already had the front roof lining off, I opted for a sharkfin type. Because the rear roof lining is a pig to remove and refit, I fitted it at the front and it looks ok. It's slightly offset from centre because there's a roof rib there but it's only an inch. It works well, FM and DAB. But if I were to do it again, I'd put it at the back where standard cars have them.
The shark fin is the neater option. But has to have a hole cut in the roof.
I’m going to live with my original aerial for a bit, see if I can get used to it then consider the options. Thanks for all your thoughts. |
