![]() | Home > Technical > Viscous fan tips |
| Tommybahama32 Member Since: 11 Sep 2017 Location: cheshire Posts: 31
Usually a good whack with a lump hammer works for me, you are aware that its a left hand thread?.
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
I think I read a post that on the tdci, it is a normal right hand thread. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
| Silver110 Member Since: 10 Jun 2020 Location: East Sussex Posts: 50
I have tried every method under the sun.
I’ve even given it a go with the hammer drill on chisel Function on the edge of the nut as I’ve seen in another thread. Have just made a long bar to put on back of the pulley tool and it’s now just ripping the spanner off the viscous nut. it is seized solid. I am turning it anti clockwise is this correct? 2008 Puma tdci |
Have you tried going clockwise? try tapping a flat bar on the flats of the nut to try and shock it.
| Rednaxela Member Since: 23 Sep 2019 Location: UK Posts: 47
Viscous fans are always undone in the same direction the fan rotates when the engine is running.
| John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 374
Correct https://www.defender2.net/forum/topic79154.html |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3786
Here’s a tip, wrap your knuckles is a towel before starting, you will take the skin off them when it goes. Ask me how I know. Twice!
| All times are GMT |
