![]() | Home > Maintenance & Modifications > Wing top chequer plate dimensions |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1902 ![]() ![]() |
Can't help you with the first question sorry, but have always believed that Mammouth are the go to manufacturer Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3748 ![]() ![]() ![]() |
Thanks carman. I’ll have a look at those guys.
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 167 ![]() ![]() ![]() |
Mine stops about 10mm short of the panel edge, at the point where it turns downward. It was fitted by the dealer when the vehicle was about a year old. There's no curve in the plate, so fitting it further out wouldn't be an option. It still disguises the dents which it doesn't entirely cover, which is partly why I had it fitted.
At the front it is about 25mm from the panel edge, with a slight downward curve. At the back, it stops 30mm short of the aerial. I imagine that different makes and different vehicles make a difference, in the usual way of aftermarket items.
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Peter (First Four) has this picture up on his eBay store - it's listed as Mammouth.
![]() Click image to enlarge Rgds. Chris |
Cheers guys. Looks good.
