![]() | Home > Maintenance & Modifications > What supports the driveshaft at the axle tube end? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3726 ![]() ![]() ![]() |
I would think the CV joint itself supports the drive shaft.
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
If you remove the stub axle the short end of the shaft/CV moves freely whereas the other end is held perfectly in the centre of the cup.
You'd think there was a bearing there but it could just be supported by the end of the axle tube and the oil seal, aided by the diff of course. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2749 ![]() ![]() |
If you remove the stub axle then the seal in the neck of the swivel ball will be supporting the weight of the shaft and CV, but once it’s all assembled the CV sits snugly into the bearing in the stub axle which keeps it in line and supports its weight.
Great, thanks for confirming.
The noise must be coming from the diff then, so may need to remove and check it ![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
