![]() | Home > Td5 > removing asr2152 air filter housing ruber bush |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2239 ![]() ![]() ![]() |
The rubber bobbin mounts should have a thin hexagonal plate at each end of the rubber section which you should be able to get a spanner on to undo them. They shouldnt be very tight.
From memory the thread is longer on one end of them than the other so you could flip them around if the longer thread is not already protruding. They captive threads should only be a standard M6x1 so you could use either a bolt or a short length of threaded bar to make some new mounts. Assume Alisport want it to be solidly mounted if they supply bolts and washers. Steve 02' 110 TD5 Double Cab Rebuild Thread |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 290 ![]() ![]() |
Hi, o.k. many thanks for the reply, I'll try getting a spanner on to the back plate nearest the bulkhead
Rgds A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
.. and it was soo simple ... course they unscrew !
minor grumble is allisport coould tell you 1). you use the rubber mounting bushes from original air box .... at £40 each not surprised 2) The sensor in the side of the airbox ... you need to have a pair of M5 bolts to mount it on the new allispot one 3). You need to use the clips that hold the MAP sensor onto the box from the original ones Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County Last edited by alexatnd on 28th Jul 2021 6:38pm. Edited 1 time in total |
except .... 3 holes on the mounting plate dont line up with threaded holes on bulkhead. You can get 2/3 but not all 3. Why they didnt just make their mounting pillars short enough for the original studs to protrude enough to fit nuts on them
So its 2 bolts and a cable tie ...... ... amd theres a small diameter rubber hose that plugs onto a pipe sticking out of the LR air box .... nowhere to go on the AlliSport one Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
