![]() | Home > Puma (Tdci) > Coolant hose clips… and fuel filter casing |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Hose clip pliers are your friend, example below - loads of makes and prices.
![]() Chris |
TXH90 Member Since: 19 Jul 2020 Location: Worcs. Posts: 54 ![]() ![]() ![]() |
Brilliant, thank you!
Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 84 ![]() ![]() ![]() |
Which bolts on the fuel filter ?
The cover is held on with a turn clip and the actual filter just unscrews from the housing. Can you attach a photo ? Kev |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 234 ![]() ![]() ![]() |
A set of extended / flexible ones are great for the hard to reach hose clips.
Hi, Yes I was expecting that too having watched the tutorial vids, sadly its an M8 bolt holding it on pretty firmly. Hoping another go at it later after the lubricant has been at it will work. Otherwise I’ve no clue..how essential is a fuel filter renewal anyway ![]() Tom |
Ah brilliant, as the the hose in question is right at the bottom of the engine bay this might be the one I need- many thanks for the heads up! Tom |
