Home > Camping, Caravanning and Holidays > Roof mounting kayaks
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Hi all,
I’m just after a bit of opinion on this set up. Does anybody see anything wrong or unsafe with it? I’m planning on strapping a second single kayak to the other side. The T brackets are welded abs bolt into the channel of the rack. I’m going to move the whole set up back a little so the straps through the kayak handles both point inward.
Thanks in advance 👍
[/img] 2002 110 td5
Post #914140 26th Jul 2021 7:25pm
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
Looks very solid Thumbs Up
I use the one shown here
https://www.canoe-shops.co.uk/reviews/thul...tacker.htm
and it looks like I could have saved myself some money doing it your way Whistle
Andy 2011 2.4 White 110 CSW LHD
1998 300TDi Wolf TUM
2015 2.2 Corris Grey 90
2009 2.4 Alaska White 110 Commercial - gone
2006 TD5 Barolo Black 90 - gone
1995 TD5 Green 90 - gone
1984 2.25 Marine Blue 88
Post #914153 26th Jul 2021 8:57pm
Jimb1978
Thanks, yes I’d seen those which made me think this was the way to go. I’ve put a socket set in to remove them when the kayaks are removed, because I just know I’ll forget about them! I’m also going to go over the welds again because I ran out of gas Evil or Very Mad 2002 110 td5
Post #914157 26th Jul 2021 9:11pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I would not trust the hand grips on the boat like that as they can give way, rather feed the straps over the whole boat and use the grips as a guide to holding the strap in place.
Vertical bars are very simple to make and dont need to be very strong, only to hold the boat on its side, with the main strap across the boat to hold in in place.
Hope that helps
our racing boats sit in V bars - by far the simplest method of carrying canoes
 Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #914173 26th Jul 2021 9:58pm
Jimb1978
Thanks Wyvern. That does make sense with regards to the carrying straps. I’ll make some adjustments today 👍 2002 110 td5
Post #914196 27th Jul 2021 7:37am
MartinK
Kari-Tek for me Thumbs Up
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #914237 27th Jul 2021 12:27pm
s55shh
easiest way is upside down with passenger holding the seat through the sunroof. Until you go downhill and a million gallons of water pour out and soak the car interior. Don't ask me how I know this...
Post #914298 27th Jul 2021 6:05pm
