Home > Maintenance & Modifications > Heated windscreen switch replacement help!
Riksbar
United Kingdom 1997 Defender 110 300 Tdi CSW Alpine White
I’m getting ready to wire in my new heated windscreen into my 300TDi, after needing to replace the windscreen recently. I have the DA1400 fitting kit and, as I was looking at how to mount the switch, I managed to unfasten the side clip, at which point the switch fell apart, a fairly key connection component dropped out with no real indication of how it had been installed originally, and one of the small spring pieces launched itself to freedom, never to be seen again. Banging Head
Is the switch a generic one I can replace or is it specific to the wiring kit?
Post #914105 26th Jul 2021 3:05pm
Do you have a a picture of the switch? Darren
Post #914107 26th Jul 2021 3:07pm
dorsetsmith
DA1400 install kit with carling switch
BMC 2-pin mini heated rear screen YUF 101680
Post #914113 26th Jul 2021 3:53pm
Riksbar
That’s the one, although my switch is now on slightly more parts!
Post #914127 26th Jul 2021 6:16pm
Ah, ok. So Carling switches are a readily available range of modular switches in a variety of flavours, on-off, on-on, mom, etc. so it should be possible buy a replacement if you know the type you need. I believe that MudUK sell them, although I'm sure that a quick search will reveal other places too. Darren
Post #914164 26th Jul 2021 9:31pm
