![]() | Home > Puma (Tdci) > Replacing a turbo? |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Do you know the fault code that was logged more recently?
Not "P0234-00 (28 ) turbo overboost condition" by any chance? > 110 XS Double Cab |
Waysider Member Since: 26 Oct 2016 Location: Surrey Posts: 9 ![]() ![]() ![]() |
I will find out the fault code when I speak to the garage. Who do you ask? Some previous experience?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
I would be cautious with this, 90k is not a high mileage for a turbo and it should not need replacing. The most likely cause of a "turbo fault" on a TDCi would be malfunction of the turbo actuator (often caused by an external wiring fault).
Landrover does not supply the actuator without the turbo, so a dealer will tell you you need a new turbo complete, whilst the actuator is available on its own from other sources (eg Ford). If it is an actuator fault, you will reduce the bill by 90% by not following Landrover's "advice" and instead replacing the actuator. Most (but not all) actuator faults are caused by mechanical damage to the wiring harness which runs round the front of the engine, and are therefore easy to fix. If you really do need a new turbo a turbo specialist will probably be substantially cheaper than Landrover. If you could provide the actual diagnostic codes we should be able to determine with more probability where the fault lies, but my advice is do not rush in to paying a huge bill!
Er, you don't have a "throttle body" on a TDCi !
It shouldn't take more than an hour (one man hour) to change a turbo on a TDCi. I am a little uneasy about your garage! |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
I second that .. 7 to 8 hours is ridiculous. I can do it on the drive in a couple of hours and I'm not a trained mechanic. Land Rover quote 90 minutes for the job.
It's highly unlikely the complete turbo is required to be changed. There's an extension to the wiring harness for the actuator available as it's tight around the front of the engine and can fail. I had a intemittent problem with this a few years ago. The extension Part number is LR020663 and it was around £25. Or as said above it could be the actuator itself. https://www.johncraddockltd.co.uk/lr020663...-tdci.html No matter what I wouldn't be going genuine parts for this or paying that amount of labour. 2008 Defender 110 XS SW - M57N2 / 8HP70X |
Have a read of this https://www.defender2.net/forum/topic79499.html > 110 XS Double Cab
The above replies are very helpful, and plenty of food for thought. Just to be clear, mine is the 2.4 diesel engine, 2010 model, 110 station wagon.
I plan to quiz my garage for more fault code details when I collect it today, and I will not commit to the repair at this stage. It is not a Land Rover dealership, but a garage called SLR in Haslemere, Surrey, which specialises in Land Rover and with staff having worked for Land Rover in the past. I have been using them for a year, and have no complaints. When they first examined this issue, in September last year, they speculated that the turbo was at fault and causing the "limp mode" to activate. I quite from their invoice: "Check fault codes...carried out smoke test on intake system. Possible leak from intercooler hose to throttle body. S&F hose. If fault returns will require new turbo". Regarding other comments made on this forum thread, can it be that to replace a turbo is a 90 minute job, or was that for something else? I am very grateful for comments so far and will add more when I collect the vehicle. If there is another recommended Land Rover garage near me, SW Surrey, I am open to try elsewhere for a "second opinion". Thanks again. |
I have collected my vehicle from the garage, and put any turbo replacement on hold, thanks to this helpful forum.
The fault code I have been given is P2263-21 turbo charger boost, system support signal. I was told that it read a fault on 13/6/21 and I have checked my diary, and that is not one of the two recent occasions when limp mode occurred. |
P2263-21 Turbocharger/Supercharger Boost System Performance- Signal amplitude < minimum
Possible Causes: Intake system blocked/leaking Manifold absolute pressure and temperature sensor fault Variable geometry turbine vane actuator fault Turbocharger failure Action: Check the intake system for blockages/leaks, check for manifold absolute pressure and temperature sensor related DTCs and perform the relevant corrective actions Check the variable geometry turbine vane actuator linkage. Check the turbocharger bearing and oil seal. Install a new turbocharger as necessary. Cut and pasted the above from B.A.S. website. > 110 XS Double Cab |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1858 ![]() ![]() ![]() |
Mine did exactly as you described, random times, and in the end would switch it off and on whilst on the motorway to get the boost back on - it was the variable vanes sticking, ignition on and off resets it.
(I had in the meantime swapped the egr, done the wiring mod and all other possibilities) I got a brand new turbo from Germany, £660 delivered plus a new gasket an afternoon swearing on the drive and all has been good since. Keith |
I have looked elsewhere, and visited a garage that confirmed what an earlier message on this thread stated - that Land Rover quote 90 minutes for replacing a turbo. This garage was also prepared to look at quality after-market turbos, so I am beginning to think I may not have to pay out the sum I was originally quoted. I am very grateful for the guidance I have received on this forum. Thank you, and any other observations are most welcome.
astroarcadia Member Since: 12 Jun 2020 Location: Gloucestershire Posts: 50 ![]() |
I have this exact problem with mine and am about to buy a new turbo complete.
I have checked hoses, sensors, the actuator arm etc. All simple cheap fixes have been exhausted. I'm going to book it in tomorrow. Can anyone recommend a garage in North Cornwall as that's where the vehicle is for the summer? Is it worth getting the EGR blanked whilst the vehicle is in the garage? |
egr blank is a digital tune as a blanking plate will light the amber fault light on your dash.
I've since seen a video where a specialist used an aerosol cleaner through the air box (filter removed) on a RR sport and fixed a similar fault - not sure I'd want to risk dislodged accumulated crud going straight into the engine though........ |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
My 60k mile 2007 also did this ^^^^ . Does your go to limp mode after a period of constant throttle position, ie tc vanes at same boost position? Does ignition cycle always clear it? Mine was yes and yes to above. I used a turbo vane cleaner direct into the turbo inlet. Resolved the problem. Ran vehicle another 18mths with no further problems. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thank you all for your contributions. I now know that my original quote for replacing the turbo was way over the top. Nevertheless, I do think all the evidence points towards me having to replace it, and as I intend to keep this vehicle, and have several quite long overland trips planned in the year ahead, I now have to decide on whether to fit a genuine Land Rover replacement at around £842 for the turbo, plus additional expenditure on additional parts plus sump drain and oil strainer replacement (to meet warranty requirements) or a reconditioned turbo at around £417 with no requirement on sump strainer etc. Given my intention to keep the vehicle, and use it on long overseas trips and a month-long Scottish highlands and islands visit this autumn, should I invest in a genuine part? Can a recon part be trusted or is it false economy. Any final thoughts please?
