Home > Puma (Tdci) > Battery alarm problems
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Has anyone had problems with the alarm connected to the battery. i.e. the alarm that goes off when you disconnect the battery.
I've been having some issues lately. It goes off when I turn the ignition. At first I opened the battery box and made sure of the connection. That would sort it out. But I have tightened that negative terminal, and this morning the same thing happened. It went of but stopped emediately.
Then all my settings are wiped out on the radio and odometer, so surely it points to the negative terminal somehow loosing connection?
Post #91336 26th Sep 2011 8:47am
Grockle
check the battary earth strap to the chassis 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #91346 26th Sep 2011 9:48am
Marius
Where on the chassis does it connect to? Close to the front or just outside the battery box?
Post #91354 26th Sep 2011 12:01pm
