Home > Td5 > A frame castellated nut - size?
Lionel
Australia
Hi,
I'll soon need to replace the A frame ball joint on my Defender 2004 TD5 Xtreme.
I want to replace the unit complete (with housing), but would like to undo the castellated nut & try to break the taper with the old unit in place before removing it.
Does anyone know the exact size of the spanner needed. There is only room for a ring spanner, unfortunately, & I'll have to buy one.
It is 28-30mm approx. (1 1/8 AF maybe?).
Any information would be appreciated.
Cheers,
Lionel
Post #913513 22nd Jul 2021 2:09am
Oldowner
30mm. It doesn’t look it but there is room to get a 1/2” drive 30mm socket on there quite easily
Post #913515 22nd Jul 2021 4:48am
dorsetsmith
1/2” drive 30mm 6 point socket with mods so it fits
not more 42mm in Hight and with 45 ground off drive end socket
Post #913527 22nd Jul 2021 8:19am
Oldowner
Elora 30mm 1/2” drive sockets fit straight in with mods
Post #913554 22nd Jul 2021 11:09am
Lionel
Australia
Thanks people,
My model doesn't have enough space between the diff casing to allow use of a socket. (Rover diff - not Salisbury). Seems to vary beween models quite a lot.
A good suggestion, but I'll try a 30mm ring spanner first, & if it won't loosen I'll probably resort to drilling the nut & a belt with the cold chisel to split it!
Cheers,
Lionel
Post #913683 23rd Jul 2021 4:02am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Ive just done mine and swapped for a gwyn lewis one.
Removed with a 30mm 1/2" socket but has to be done up with a 30mm ring spanner on a 90.
Jack the body high enough so the spanner doesnt foul on the tank.
Will add pictures
Post #913825 23rd Jul 2021 8:42pm
LandymanStefan
Post #913827 23rd Jul 2021 8:43pm
Lionel
Australia
Thanks LandymanStefan,
My 2004 110 TD5 has a P38 rear diff, & the bracket which the 30mm nut attaches to is welded to the diff casing. (Looks like your 90 is the same). This removes the option of removing the whole thing & working with a vice on the bench. (Grrr!!)
A colleague on another forum has directed me to a Daytona 30mm impact 6 point socket which is 42mm in height & should fit. He has the same setup on his 2005 TD5 as on mine, so hopefully that will work.
Cheers,
Lionel
Post #913847 24th Jul 2021 5:10am
LandymanStefan
I got my impact socket in to remove it but when I comes to tightening there’s no chance. I bought 2 extra different shaped sockets, standard and and stubby impact one. Neither would go near it.
Post #913849 24th Jul 2021 7:51am
Lionel
Australia
That's interesting! Why would you be able to undo the nut with a socket, but not be able to tighten the new one?
Was it something to do with the characteristics of the Gwyn Lewis replacement assembly? If so, that is disappointing, as I was thinking of ordering one for mine. Wink
Cheers,
Lionel
Post #913853 24th Jul 2021 8:17am
LandymanStefan
I think it’s just the position of the nut when it’s at the bottom of the thread. Nearer the bottom of the thread you’re closer to the axle and you can’t squeeze the socket in. When I was undoing it I can’t say I was on it square either just managed to blitz it off. Laughing
Post #913860 24th Jul 2021 10:31am
Lionel
Australia
Just a follow up. I did the job last Wednesday & it was not too easy, mainly due to a ferociously tight castellated nut. I had obtained a Daytona 30mm impact socket, & modified it as dorsetsmith suggested, so no problem there. Thanks very much for the info.
My Milwaukee 18V impact driver wouldn't go near undoing the nut, which shocked me rather, as it was the 1st time the Milwaukee had failed to undo anything previously on the Defender! Heating up the nut with a small blow torch got it to undo though.
The next thing was the taper joint which was MOST reluctant to separate. I had the car on axle stands under the chassis to take the weight off the wheels, but I also put a jack under the A frame bracket itself to lift the wheels just off the floor, so the whole weight of the rear axle & wheels was held by the taper joint. Then I used the blow torch again. After about 2 minutes of heating, the taper separated with a very satisfying BANG.
After that it was very straightforward to clean everything up & fit the new bracket assembly. Although there seemed to be very little play in the old one (the boot was split), the car does feel better on the road, so there must have been a little bit of unwanted axle movement.
All good, & thanks to you all for your help.
Cheers,
Lionel
Post #916853 14th Aug 2021 2:31am
