Home > In Car Electronics > Single din head unit with camera. Options please
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Hi. First question here on this great forum. Read so much great info from other Landy lovers!
Don’t really want the faff of going double din. Unless you convince me otherwise.
So I think I’m after single din. Wants/needs are a reversing camera, Bluetooth and possible Apple CarPlay.
I’ve seen loads of cheap Chinese jobbies that seem to do a reasonable job, however I’ve read the sound quality is lacking. as is CarPlay. Hope to do a focal speaker upgrade next so want a decent sound source.
Any recommendations? Fixed unit or flip out? Pros, cons?
2014 110 xs all factory at present with factory sub.
Mark
Post #913288 20th Jul 2021 8:36pm
Gasket
There are a few single DIN with everything you want (except carplay) - the JVC KD-X56XXX series are priced between £140-£200 and look OK to me.
Carplay is the issue - there are a few "Halo" systems (single din chassis, wth a fixed double-din floating screen), but as far as I'm aware there aren't many true single din (or motorised) options: the only one I can think of is the pioneer one:
https://www.caraudiocentre.co.uk/product_m...-41153.htm
Halo ones would block the clock and hazard switch on a Puma.
I'm in exactly the same boat and coming to the conclusion that you can pick up a carplay doble din and a double din facia panel for a similar price to the above one from pioneer.
Post #913299 20th Jul 2021 10:11pm
Gasket
deleted: double post
Post #913300 20th Jul 2021 10:11pm
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I also have the JVC and so far it has been brilliant.
Fabio
Post #913327 21st Jul 2021 5:25am
iforland
United Kingdom 1986 Defender 90 200 Tdi HT Arles Blue
I'm look at this unit for a motorhome I have, but would work in the Defender also Sony XAV-AX8050D, I think it ticks all your options, it is not a motorised screen, its fixed but you can put it in many different positions.
Post #913355 21st Jul 2021 8:48am
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
I just bought my replacement 110 and it came with the Pioneer unit mentioned above and I'm really quite chuffed with it. I didn't realise it had a DAB unit in it until I picked it up so had been considering splashing out £400 on a Blaupunkt Bremen and £150 or so on a sat nav unit. Given this one also has carplay I don't need the satnav now either so a big thumbs up for this one even though it is a bit pricey.
Post #913366 21st Jul 2021 9:38am
pilsburypie
Cheers for the info. That pioneer looks the dogs. But pricey. The JVC is very popular and is a good price but looses CarPlay. Might have to get over that. Need some funds to sort an amp and some speakers.
Post #913462 21st Jul 2021 5:20pm
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
I’ve got the pioneer with factory sub and focal speaker upgrade. Honestly no need for a separate amp more sound than I know what to do with. https://instagram.com/bentheoandrews
Post #913493 21st Jul 2021 9:00pm
pilsburypie
I don’t have the premium package for sound so no sub. Was thinking of the focal es100k speakers and tweeters and the ibus 20 sub.
That pioneer looks the bomb. How do you find it affects your switches? I suppose the screen away button sorts that?
Post #913497 21st Jul 2021 9:26pm
Farmerben
Mine didn’t come with the sub - got one off eBay as there was already the plug under the cubby to go to the head unit pre wired for it. Just needed a live taking off the battery and job done.
Only switch I have a problem with is hazard light but if I ever need it it’s just a press of the button to flip the screen down and out of the way. Benefits far outweigh any downsides.
Best thing about one with CarPlay is that the software is on the phone so unless there’s some huge fundamental change in how it works, it will be as up to date as your phone is. https://instagram.com/bentheoandrews
Post #913516 22nd Jul 2021 5:34am
