![]() | Home > Td5 > Safari Snorkel |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 975 ![]() ![]() ![]() |
Does it not use the same holes as the side intake? And yes there is supposed to be a thin foam gasket around the intake. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2670 ![]() ![]() ![]() |
You can buy a sheet of adhesive back neoprene off of eBay and make your own. They are available in many different thicknesses.
DevonJas Member Since: 06 Apr 2021 Location: Devon Posts: 5 ![]() ![]() ![]() |
Thanks for the reply, any idea what thickness would be best? What do the Safari company use?
My current roll is 3mm thick.
Surprisingly useful stuff to have in the garage… |
I wouldn't fit a safari one, I removed mine from my TD5 as it kept filling up with water as the neoprene seal failed.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
I just bond snork to wing with tiger seal. It won’t fail, and the neoprene traps all the crap and trashes your paint anyway. At least I know mine is sealed.
