Home > Technical > 300TDi clutch issues
Page 2 of 2 <12
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Time to drag up this old post as I have finally got round to looking at it again.
Having tried everything with the LOF powerslave and Lof spring, original spring and no spring I am in a position where the pedal returns but all of the clutch action happens (barely) within an inch of the floor.
I am starting to think something along the lines of bent fork or pressure plate having gone. Would anyone like to give me a clue on this please? 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #912079 12th Jul 2021 7:38pm
donmacn
Sorry to hear it's still an issue.
It could very well be the fork, going if not gone. Did you chat to Luke at LOF?
Here's an off-the-wall suggestion.... one of the LR mags (think it was LRO) had a review not so long ago for an endoscope that worked on android phones. It was about £38 so I gave it a shot and have been very happy with it - used it to check for leaks at the back of my RR V8 valley gasket, and down the inlet manifolds.
For £38 it might be easier than pulling the gearbox back just to check...? There's even a wee mirror attachment so that if you got the scope beyond the clutch fork, you might be able to look down and see if the fork is punching through??
And you never know what other uses you might find for an endoscope... Whistle Laughing Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #912086 12th Jul 2021 8:20pm
300TDi CSW Phil
After many hours in under and around the Defender the problem has been found.
So a new heavy duty clutch fork and release bearing is definitely necessary and the friction plate has about 0.75mm of material over the closest rivets to the surface.
Now to choose between LOF Roadspec and Powerspec kits and start the rebuild.
Any recommendations welcome. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #912739 16th Jul 2021 9:26pm
donmacn
Ouch! That's an unusual one. I'm sure I read something about some sort of pressure lock thing keeping pressure on the fork - though I'm afraid I can't remember where, and probably irrelevant at this stage. I do wonder why it went there though.
I have a LOF powerspec clutch fitted. I've been really impressed with the quality of the stuff, and with Luke's willingness to help out on the phone ( I had an issue with setting the pedal height initially) so I'd recommend LOF myself. Donald
in the past..
Post #912747 16th Jul 2021 11:45pm
300TDi CSW Phil
All ordered powerspec plus new necessary bits off to pick it up shortly. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #912752 17th Jul 2021 8:28am
300TDi CSW Phil
Picked up the new kit and bits required at lunchtime. Luke was an absolute star and a pleasure to meet going out of his way to help me.looking forward to getting it all back together on Monday and back on the road. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #912827 17th Jul 2021 8:19pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
I think that is already somebody's idea of a HD clutch fork, they don't usually have that 'reinforcement' plate welded on to cover the back of the pivot cup. Perhaps take some additional care of choosing a HD replacement. Simply welding a metal plate onto the back of a fork made of recycled monkeymetal does not turn a cheap, nasty fork into an indestructible HD item! There is plenty of shonky tat out there advertised as an 'upgrade'......
Post #912990 18th Jul 2021 11:46pm
Page 2 of 2 <12
