![]() | Home > Puma (Tdci) > Leaking transfer case |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Where is the new leak coming from? Rgds.
Chris |
Ijk10 Member Since: 01 Apr 2021 Location: Newport Posts: 37 ![]() ![]() ![]() |
The garage have said it's at the top end of the rear...
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
Hi. I see you’re in Newport. Which garage did you use? > 110 XS Double Cab
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17871 ![]() ![]() ![]() |
Probably time to change garage!
The only cause of a leak which might justify the "replacement transfer box required" comment would be if the leak is due to the enlargement of the holes in the casing which support the second motion (aka idler gear) shaft. There are ways to repair this. Such a leak wouldn't be coming from the "top end of the rear", however. |
Sent you a dm buddy...
